[gdal-dev] Tiling aerial photos
Paul Meems (Top-X) p.meems at topx-group.nl
Thu Jul 12 05:38:09 PDT 2012
Thanks Duarte and Etienne,
That is very useful information.
I wouldn't thought about it reading just the documentation.
Thanks,
Paul
2012/7/12 Etienne Tourigny <etourigny.dev at gmail.com>
> You should generate the stats for every file, as you will probably get
> incorrect results with your method
> for f in *.tif; do gdalinfo -stats $f ; done
> On Thu, Jul 12, 2012 at 9:03 AM, Duarte Carreira <DCarreira at edia.pt>
> wrote:
> > Hi Paul.
> > I had to build a big vrt. The one trick that got it loading very fast
> into
> > qgis was adding statistics to each rasterband:
> >   <Metadata>
> >       <MDI key="STATISTICS_MAXIMUM">255</MDI>
> >       <MDI key="STATISTICS_MEAN">111.6784426525</MDI>
> >       <MDI key="STATISTICS_MINIMUM">0</MDI>
> >       <MDI key="STATISTICS_STDDEV">52.100074055799</MDI>
> >     </Metadata>
> > I just got stats from a subset and used that for all bands.
> > Duarte
> > De: Paul Meems (Top-X) [mailto:p.meems at topx-group.nl]
> > Enviada: quinta-feira, 12 de Julho de 2012 12:11
> > Para: gdal-dev at lists.osgeo.org
> > Assunto: Re: [gdal-dev] Tiling aerial photos
> > Thanks Dmitry and Even,
> > The aerial photos are north-up and are in the same projection and I think
> > also in the same resolution.
> > It are commercial aerial photos.
> > The Correlator project sounds very interesting but not necessary in my
> case.
> > I'll try to implement the VRT format and see what the performance will
> be.
> > If it is fast we don't need to tile.
> > Thanks,
> > Paul
> > 2012/7/12 Even Rouault <even.rouault at mines-paris.org>
> > Selon "Paul Meems (Top-X)" <p.meems at topx-group.nl>:
> >> Thanks Even,
> >> http://www.gdal.org/gdalbuildvrt.html does seems very interesting.
> >> As I understand it, it will do the merging part (without actually
> >> merging).
> > The VRT driver will do on-the-fly merging of tiles that have overlapping.
> > The
> > VRT itself is just a XML file.
> >> But it doesn't do the tiling part, right?
> > No, I wasn't sure if your photos were already regularly tiled or not.
> Note
> > that
> > the VRT accepts non regularly tiled images. They can have overlapping,
> gaps,
> > different resolutions, etc. The main constraints are :
> > - they are in the same projection
> > - they are "north-up", that is to say there is no rotation or skewing
> term
> > in
> > their geotransform matrix
> > - they have the same number of bands
> >> Or is the vrt so optimized tiling
> >> is no longer necessary?
> > Not necessary. Note that the VRT has no internal spatial indexing, so if
> you
> > have several dozains of thousands of images in a VRT, it might slow down
> > because
> > it will iterate over all the image descriptions (without needing to open
> > them
> > however, all the information is in the VRT) to see if they intersect with
> > the
> > request window. But I'd expect the number of images in the VRT to be
> really
> > high
> > for that effect to become noticeable.
> >> Thanks,
> >> Paul
> > 2012/7/12 Dmitry Baryshnikov <polimax at mail.ru>
> > 12.07.2012 14:36, Paul Meems (Top-X) пишет:
> > Thanks Even,
> merging).
> > But it doesn't do the tiling part, right? Or is the vrt so optimized
> tiling
> > Thanks,
> > Paul
> >> Hi list,
> >> I have several aerial photos and I use MapWindow GIS to view them.
> >> MapWindow is already using GDAL v1.8
> >> Instead of loading each aerial photo as an individual layer I want to
> >> create a local tiles store of the photos.
> >> I can then just load the tiles I need based on the scale and view. This
> >> will most likely improve the performance.
> >> The process will be something like this:
> >> 1. Get the filenames of the photos
> >> 2. Merge them into one
> >> 3. Create tiles
> >> 4. Put the tiles in a SQLite database
> >> My first question: Is the above suggested process correct or should I do
> >> it
> >> differently?
> >> My second question: What GDAL functions should I look into to accomplish
> >> my
> >> process?
> > You could try to make a VRT from all your photos. It will be seen as a
> > single
> > GDAL dataset, and will take care of the burden of opening the underlying
> > photos
> > when needed. You can use the gdalbuildvrt utility to create the VRT from
> the
> > photos.
> >> Thanks,
> >> Paul Meems
> >> The Netherlands
> > gdal-dev mailing list
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
> > There is an interesting work connected aerial imagery:
> > http://trac.osgeo.org/gdal/wiki/Correlator
> > http://correlatorgsoc2012.blogspot.com/
> > Best regards,
> >     Dmitry
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120712/16882301/attachment.html>
