[gdal-dev] installing debian GDAL version >= 1.9
Etienne Tourigny etourigny.dev at gmail.com
Thu Jul 12 06:59:09 PDT 2012
Isn't there a debian repository (debiangis) that provides gdal-1.9 ????
Etienne
On Thu, Jul 12, 2012 at 10:41 AM, Tom Roche <Tom_Roche at pobox.com> wrote:
> summary: how to prevent or fix
> me at it:/tmp/gdal$ dget --build http://ftp.de.debian.org/debian/pool/main/g/gdal/gdal_1.9.0-3.dsc
> ... much, much later ...
>> error: could not create '/usr/local/lib/python2.6/dist-packages/osgeo': Permission denied
>> error: could not create '/usr/local/lib/python2.7/dist-packages/osgeo': Permission denied
>> make[1]: *** [install] Error 1
>> make[1]: Leaving directory `/tmp/gdal/gdal-1.9.0/swig/python'
>> make: *** [build-stamp] Error 2
>> dpkg-buildpackage: error: debian/rules build gave error exit status 2
> noting that `sudo` is no fix (more below)?
> details:
> Tom Roche Tue, Jul 10, 2012 7:13 PM
>>>> me at it:~$ aptitude search ~Dlibfontconfig1 | grep -e '^i' | less
>>>> appears to show many important dependencies (e.g., emacs, xulrunner,
>>>> cinnamon, gnome-shell, MATE). Am I missing, or misinterpreting,
>>>> something? If not, is there a better/safer way for me to upgrade my
>>>> GDAL to version >= 1.9?
> Mikhail Titov Wed, 11 Jul 2012 01:26:55 -0500
>>> You can give a try rebuilding just that package. If you are lucky it
>>> won't pull much else.
>>> This [1] may help to get an idea.
>>> [1] http://ask.debian.net/questions/how-to-install-from-experimental-on-natty-gdal-1-9
> Thanks! The good news is, I didn't hafta pull from experimental:
>> gdal-bin_1.9.0-3+b1_amd64.deb 25-Jun-2012 09:03   325K
>> gdal_1.9.0-3.dsc              05-Jun-2012 15:47   2.2K
> Even better, I didn't need an uplevel libfontconfig1! and I only had to
> touch my sources.list once, to get libsqlite3-dev version=3.7.13-1!
> So the build was *almost* painless, except ...
> 1 It was a slog ... the kind of loonnnggg build that induces anxiety
>   about the size of one's /tmp, about vulnerabilities to one's
>   electrical grid, about the impending heat death of the universe :-)
>   But such is life, when building on an older laptop.
> 2 After fiddling with the build dependencies,
>   failed with
>   I thought the fix might be to run as root, but that also failed
>   (but quickly):
> me at it:/tmp/gdal$ sudo dget --build http://ftp.de.debian.org/debian/pool/main/g/gdal/gdal_1.9.0-3.dsc
>> dget: retrieving http://ftp.de.debian.org/debian/pool/main/g/gdal/gdal_1.9.0-3.dsc
>> dscverify: gdal_1.9.0-3.dsc failed signature check:
>> gpg: keyblock resource `/root/.gnupg/secring.gpg': file open error
>> gpg: Signature made Tue 05 Jun 2012 09:24:57 AM EDT using DSA key ID E9F2C747
>> gpg: fatal: /root/.gnupg: directory does not exist!
>> secmem usage: 1408/1408 bytes in 2/2 blocks of pool 1408/32768
>> Validation FAILED!!
>   So how to fix the /usr/local/lib/python2.x/dist-packages/osgeo fails?
> TIA, Tom Roche <Tom_Roche at pobox.com>
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
