[gdal-dev] Error LNK1120: 314 unresolved externals - When using Ogr C++ class on Visual Studio 2010
taibc
taibc_coltech at yahoo.com
Fri Jul 13 00:54:45 PDT 2012
Ok, thank you !
Kind regards,
Tai
From: Dmitry Baryshnikov [via OSGeo.org] <ml-node+s1560n4988142h21 at n6.nabble.com>
To: taibc <taibc_coltech at yahoo.com>
Sent: Friday, July 13, 2012 2:44 PM
Subject: Re: Error LNK1120: 314 unresolved externals - When using Ogr C++ class on Visual Studio 2010
13.07.2012 11:18, taibc пишет:
>What are exported classes/methods ?
>I only created a file: main.cpp to show the word "Hello", and
added Ogr files into my project, then built it.
>Please see the attached file.
>My idea is: I will create functions in the main.cpp file that
use methods of Ogr class to allow convert .dgn files to shape
files.
>Thanks and regards,
>Tai
>View this message in context: Re: Error LNK1120: 314 unresolved externals - When using Ogr C++ class on Visual Studio 2010
>>Sent from the GDAL - Dev mailing list archive at Nabble.com.
>>_______________________________________________
gdal-dev mailing list [hidden email] http://lists.osgeo.org/mailman/listinfo/gdal-dev
>After linking, you can use only exported classes and
methods. It seems to me you try to use not exported
method. Maybe some your code can help.
>Best regards,
> Dmitry
>[hidden email]
>If you reply to this email, your message will be added to the discussion below:
http://osgeo-org.1560.n6.nabble.com/Error-LNK1120-314-unresolved-externals-When-using-Ogr-C-class-on-Visual-Studio-2010-tp4988103p4988133.html
>To unsubscribe from Error LNK1120: 314 unresolved externals - When using Ogr C++ class on Visual Studio 2010, click here.
>NAML
> Error.jpg (343K) Download Attachment
You mast remove any cpl_*.cpp and any gdal headers from your
solution. In project properties you have to put path to gdal headers
(gdal_root/port, gdal_root/gcore, gdal_root/ogr)
E.g. for GDALVersionInfo function you have to include only in your
code #include "gdal.h"
Best regards,
Dmitry
[hidden email]
http://osgeo-org.1560.n6.nabble.com/Error-LNK1120-314-unresolved-externals-When-using-Ogr-C-class-on-Visual-Studio-2010-tp4988103p4988142.html
NAML
View this message in context: http://osgeo-org.1560.n6.nabble.com/Error-LNK1120-314-unresolved-externals-When-using-Ogr-C-class-on-Visual-Studio-2010-tp4988103p4988144.html
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120713/474d124a/attachment-0001.html>
