[gdal-dev] Memory leaks when using SQL queries with shapefiles
Even Rouault
even.rouault at mines-paris.org
Fri Jul 13 03:14:51 PDT 2012
Selon Pierluigi Guasqui <guasqui at actgate.com>:
> Hello,
> I am experiencing a big memory allocation (with no subsequent memory
> release) when using SQL queries with shapefiles. This is a sample code
> that triggers this problem:
> OGRRegisterAll();
> // opening shapefile data source
> const char *fname = "path/to/shapefile.shp";
> OGRDataSource *poDS;
> poDS = OGRSFDriverRegistrar::Open( fname, FALSE );
> if( poDS == NULL )
> fprintf( stderr, "%s: could not open input file\n", fname );
> return -1;
> // creating the spatial filter
> OGRLineString regionPolygon;
> OGRRawPoint *pointsList = new OGRRawPoint[5];
> pointsList[0].x = -180; pointsList[0].y = 90;
> pointsList[1].x = 180; pointsList[1].y = 90;
> pointsList[2].x = 180; pointsList[2].y = -90;
> pointsList[3].x = -180; pointsList[3].y = -90;
> pointsList[4].x = -180; pointsList[4].y = 90;
> regionPolygon.setPoints(5, pointsList);
> delete[] pointsList;
> // executing the query
> const char *query = "SELECT * FROM table_name WHERE some_field LIKE
> '%bla%' ORDER BY some_other_field";
> OGRLayer *rs = poDS->ExecuteSQL( query, ®ionPolygon, NULL );
> // releasing memory
> poDS-> ReleaseResultSet( rs );
> OGRDataSource::DestroyDataSource( poDS );
> With a 100.000 records shapefile "ExecuteSQL" has allocated over 300
> MBytes of memory with no deallocation when calling "ReleaseResultSet".
> The memory leak is triggered only when "ExecuteSQL" is called with a
> spatial filter (even trivial as shown in the above code) and the SQL
> query contains a 'WHERE' clause and an 'ORDER BY' clause. Is this a bug?
> I am using GDAL 1.9.1 under Windows platform.
> Any help would be really appreciated!
Pierluigi,
I have not a dev environmenet at the moment to investigate that, but could you
open a ticket in GDAL Trac with all the details so it does not get lost ?
Are you positive that, all other things unchanged, the presence of the spatial
filter makes a difference ? I'm not sure how you check on Windows if the memory
is really released (if you put your code in a while(1) {} loop, does the memory
used by the process increase at each iteration ?).
I also suspect that your spatial filter will not do what you would (probably)
expect from it. The geometry of the filter is a LINESTRING, not a POLYGON. So it
will only filter geometries that intersect the line, not geometries that are
fully inside it.
Best regards,
Even
