[gdal-dev] ogr2ogr and reserved words
Ivan Lucena ivan.lucena at princeton-ma.us
Fri Jul 13 06:59:41 PDT 2012
Thanks Even. Very good answer as always.
>  -------Original Message-------
>  From: Even Rouault <even.rouault at mines-paris.org>
>  To: Ivan Lucena <ivan.lucena at princeton-ma.us>
>  Cc: gdal-dev at lists.osgeo.org <gdal-dev at lists.osgeo.org>
>  Subject: Re: [gdal-dev] ogr2ogr and reserved words
>  Sent: Jul 13 '12 08:41
>  Hi Ivan,
>  > Is there any trick to avoid creating field names with reserved words? For
>  > example, a DBF from a shapefile can have field names like "long" and other
>  > formats may not like it.
>  It is up to the output driver to do whatever sanitizing it requires. This is
>  already done in a lot of drivers. The last recollection I have is in the FGBD
>  driver that modifies field names that match a list of reserved keywords. The
>  shapefile driver will also truncate too long field names, etc.. A bunch of RDBM
>  drivers have a LAUNDER creation option too. etc etc.
>  I suspect your question might be related to the OCI driver ? Perhaps it should
>  do something like the above if needed.
>  ogr2ogr is able to deal with drivers that have an implementation of
>  CreateField() that does a renaming/truncation/etc... of the source field name.
>  You also have the possibility to use the AS capability of OGR SQL to do the
>  renaming manually.
>  > Regards,
>  > Ivan
>  > _______________________________________________
>  > gdal-dev mailing list
>  > http://lists.osgeo.org/mailman/listinfo/gdal-dev
