[gdal-dev] Temporal statistics
Etienne Tourigny
etourigny.dev at gmail.com
Fri Jul 13 07:19:09 PDT 2012
Provided you can convert the format to netcdf, you could use a tool
like cdo which does exactly what you want
"CDO is a collection of command line Operators to manipulate and
analyse Climate and NWP model Data."
https://code.zmaw.de/projects/cdo/
gdal supports netcdf output, you might have to do some fixing up of
the time axes though.
Basically I would do
- loop on each file:
- convert to netcdf
- set the time axis with cdo settime <def>
- merge all files: cdo mergetime <infiles> outfile.nc
- operate on the resulting file with cdo operators (cdo timmean, cdo
timmax, etc)
Cheers
Etienne
On Fri, Jul 13, 2012 at 11:01 AM, Knut-Frode Dagestad
<knutfrodesoppel at hotmail.com> wrote:
> Hi,
> From a time series of colocated images, I construct a VRT with one band
> for each time step using gdalbuildvrt:
>> gdalbuildvrt -separate mtsat.vrt mtsat/*_IR*00.tif
> Are there any tools that can be used to calculate some statistics (min,
> max, mean, etc) versus time for each pixel of such a 3D Dataset?
> The rasters are large and timeseries long, so reading everything into a
> Python NumPy cube is not a good solution.
> Thanks,
> Knut-Frode
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
