[gdal-dev] Ogr: ExecuteSQL with MSSQL and geometry column
Benjamin benjamin.lux at maxsea.fr
Wed Jul 18 06:01:04 PDT 2012
Sorry, I was not clear.
I resume from the beginning.
I work with a warper C# of Ogr.
I have a table dbo.MY_TABLE with 3 fields (D, CHART_ID, WKB_GEOMETRY) in a
SQL server Database (in SQL Azure exactly).
*My aim is to work with a copy* (in a
http://www.gdal.org/ogr/drv_memory.html Memory DataSource ) of a SQL
statement result executed on a MSSQL DataSource.
Actually I can work with usuals methods with this MSSQL DataSource.
Note that I have not geometry_column table in my SQL Serveur DataBase, I use
http://www.gdal.org/ogr/drv_mssqlspatial.html driver options .
[code]
string driverOptions =
"Tables=dbo.MY_TABLE(WKB_GEOMETRY);GeometryFormat=wkb;"
serverDataSource = Ogr.Open("MSSQL:" + connectionString + driverOptions),
0);
serveurDataSource.GetLayerCount(); // It works fine.
[/code]
So I tried a call to
http://www.gdal.org/ogr/classOGRDataSource.html#aa6acc228db6513784a56ce12334a8c33
SQLExecute() .
[code]
string request = "*SELECT * FROM MY_TABLE WHERE CHART_ID = 'ID'*"
Layer serverLayer = serverDataSource.ExecuteSQL(request, null, "");
[/code]
But unfortunately, I have not geometry field in the result.
[code]
serveurLayer.GetGeometryColumn();  //*return ""*
serveurLayer.GetGeomType();          //*return wkbUnknown*
[/code]
But I have my 3 fields in serveurLayer !
[code]
serverLayer.GetLayerDefn().GetFieldCount();                //return 3
serverLayer.GetLayerDefn().GetFieldDefn(0).GetName(); //return "D"
serverLayer.GetLayerDefn().GetFieldDefn(1).GetName(); //return "CHART_ID"
serverLayer.GetLayerDefn().GetFieldDefn(2).GetName(); //*return
"WKB_GEOMETRY"*
[/code]
So I want to copy this layer in a Memory Layer to minimise acces to my SQL
Server and work faster.
[code]
Driver memDriver = Ogr.GetDriverByName("Memory");
DataSource memDataSource =
memDriver.CreateDataSource(GetWorkPath("nomimprobale"), null);
Layer memLayer = memDataSource.CopyLayer(serverLayer, layerName, null);
[/code]
Now,* I have to fetch my geometries*, so have thought to a trick like this :
[code]
byte[] memWkb =
System.Text.Encoding.UTF8.GetBytes(memFeature.GetFieldAsString("WKB_GEOMETRY"));
Geometry memGeom = Geometry.CreateFromWkb(memWkb);
[/code]
Because I can't use memFeature.GetGeometryRef()
[code]
memFeature.GetLayerCount();                                // return 39
Feature memFeature = memLayer.GetNextFeature();  // don't return null
memFeature.GetGeometryRef();                             // *return null*
[/code]
But I don't know if I have to use UTF8, ASCII, Unicode or other.
If you know what encoding is use, or better an other trick to have a
geometry in my memLayer or serverLayer I heard you with interest !
Sorry for my spelling, English isn't my native tongue language.
Benjamin
Ps : link to the thread:
http://osgeo-org.1560.n6.nabble.com/gdal-dev-Ogr-ExecuteSQL-with-MSSQL-and-geometry-column-tp4988831.html
Even Rouault wrote
> Selon Benjamin <benjamin.lux@>:
>> "You can access the geometry like with any other ogr feature."
> Hopefully, memFeature.GetGeometryRef() should do it !
> gdal-dev mailing list
> gdal-dev at .osgeo
View this message in context: http://osgeo-org.1560.n6.nabble.com/gdal-dev-Ogr-ExecuteSQL-with-MSSQL-and-geometry-column-tp4988831p4989072.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
