[gdal-dev] How to identify a point is belong to a polygon ?
Chaitanya kumar CH chaitanya.ch at gmail.com
Sat Jul 21 02:13:05 PDT 2012
Tai,
Pease refer to http://trac.osgeo.org/geos/
On Sat, Jul 21, 2012 at 2:06 PM, taibc <taibc_coltech at yahoo.com> wrote:
> Thanks Chaitanya,
> I tried to install GEOS on Window.
> But I got below error: NMAKE fatal error U1077 ....return code '0x2'
> Detail is:
> algorithm\LineIntersector.cpp(671) : error C3861: 'isnan': identifier not
> found
> algorithm\LineIntersector.cpp(672) : error C3861: 'isnan': identifier not
> found
> algorithm\LineIntersector.cpp(680) : error C3861: 'isnan': identifier not
> found
> algorithm\LineIntersector.cpp(681) : error C3861: 'isnan': identifier not
> found
> algorithm\LineIntersector.cpp(736) : error C3861: 'isnan': identifier not
> found
> algorithm\LineIntersector.cpp(737) : error C3861: 'isnan': identifier not
> found
> NMAKE : fatal error U1077: '"C:\Program Files\Microsoft Visual Studio
> 10.0\VC\BI
> N\cl.EXE"' : return code '0x2'
> Stop.
> 10.0\VC\BI
> N\nmake.EXE"' : return code '0x2'
> Stop.
> chaitanya_ch wrote
> > Tai,
> > GDAL needs GEOS to perform these geometry functions. Make sure you
> install
> > that.
> > On Sat, Jul 21, 2012 at 12:19 PM, taibc <taibc_coltech@> wrote:
> http://osgeo-org.1560.n6.nabble.com/How-to-identify-a-point-is-belong-to-a-polygon-tp4989501p4989779.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120721/703910df/attachment.html>
