[gdal-dev] New OGR driver to read OpenStreetMap .osm / .pbf files
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Mon Jul 23 06:31:41 PDT 2012
Even Rouault wrote:
23. heinäkuuta 2012 13:27
> Le lundi 23 juillet 2012 00:09:05, Jukka Rahkonen a écrit :
>> Even Rouault <even.rouault <at> mines-paris.org> writes:
>> > > > However, select with SQL feels sub-optimal.
>> > > Yes, when you use ogr2ogr with explicit layer names, there are
>> > > optimizations. For example, when you only specify the layer 'points',
>> > > the OSM driver will not even try to index the nodes into the temporary
>> > > database because it is not needed. However, as you noticed, there is
>> > > not yet any optimization when a SQL request is specified.
>> > Optimization for SQL request added in r24690
>> I had a try with r24696 today, downloaded from
>> http://gisinternals.com/sdk/Download.aspx?file=release-1500-gdal-mapserver.
>> zip
>> Filtered commands give me errors. An example:
>> ogr2ogr -f "ESRI Shapefile" test germany.osm.pbf multipolygons -gt 20000
>> -progress --config OGR_SQLITE_SYNCHRONOUS OFF -where "natural='forest'"
>> ERROR 1: Failed inserting node 420797898: database schema has changed
> I could also reproduce and I suppose there was at the begnning of the sequence
> of errors : "ERROR 1: Failed inserting node XXXX: I/O error"
Most probably yes but I saw only the last lines of the first thousand which were
printed on the screen.
> It turned out that the mechanism to transfer the temporary in-memory DB file to
> disk when it is too big had been broken by a previous commit, so it stayed on
> RAM and at some point, it couldn't fit in RAM, hence the error. Should be fixed
> now with r24699.
> I'm experimenting with removing the internal use of SQLite for the temporary
> database and replacing it with something custom. Actually, it won't replace it
> completely in all cases, but it could definitely be used in well-behaved cases
> where the elements in the .osm/.pbf are listed in increasing id order, which
> is the case of the data in geofabrik files for example. The first results seem
> to show increased performance.
> Note: in your above example, you don't need to specify -gt and --config
> OGR_SQLITE_SYNCHRONOUS OFF when the output format is not sqlite/spatialite.
> And the internal use of SQLite in the OSM driver already sets the
> corresponding parameters to the values that give the best performance.
Sure true with extra parametes, I just forgot to remove them when doing
a quick verification for seeing if the error occurs similarly for spatialite and
shapefile outputs.
-Jukka-
