[gdal-dev] how to create NETCDF with several 3D variables?
Anton Korosov
anton.korosov at nersc.no
Mon Jul 23 07:50:30 PDT 2012
Dear list,
how to create a NetCDF file with several variables that have more than
two dimensions?
I have to save time series of several fields (sst, chlorophyll, etc) in
one file.
I found that in order to create one 3D variable I can add
NETCDF_DIM_EXTRA, NETCDF_DIM_time_DEF, NETCDF_DIM_time_VALUES to the
metadata in a VRT file. Then I use 'gdal_translate -of NetCDF' or
gdal.GetDriverByName('NetCDF').CreateCopy() to generate a .nc file.
However I cannot make several 3D variables!
Here are two VRTs. One works fine (one variable: 'sst', 3 dimentions:
time, x, y). Another one produces two variables (chl, sst) but time
dimension is not added!
Is it possible to do it in theory?
I use the latest release of GDAL 2.0dev
With best regards and great thanks for the developers of the fantastic
NetCDF driver!
Anton
<VRTDataset rasterXSize="4320" rasterYSize="2160">
<SRS>GEOGCS["Clarke_1866",DATUM["Clarke_1866",SPHEROID["Clarke 1866",6378206.4,294.9786982139006]],PRIMEM["Greenwich",0],UNIT["degree",0.0174532925199433]]</SRS>
<GeoTransform> -1.7999999491497874e+02, 8.3333335816860199e-02, 0.0000000000000000e+00, 9.0000002544373274e+01, 0.0000000000000000e+00, -8.3333335816860199e-02</GeoTransform>
<Metadata>
<MDI key="NETCDF_DIM_EXTRA">{time}</MDI>
<MDI key="NETCDF_DIM_time_DEF">{3,6}</MDI>
<MDI key="NETCDF_DIM_time_VALUES">{0,1,2}</MDI>
</Metadata>
<VRTRasterBand dataType="Int16" band="1">
<Metadata>
<MDI key="NETCDF_DIM_time">0</MDI>
<MDI key="NETCDF_VARNAME">sst</MDI>
</Metadata>
<ColorInterp>Gray</ColorInterp>
<SimpleSource>
<SourceFilename relativeToVRT="1">gdal_test/alwdgg.tif</SourceFilename>
<SourceBand>1</SourceBand>
<SourceProperties RasterXSize="4320" RasterYSize="2160" DataType="Int16" BlockXSize="4320" BlockYSize="1" />
<SrcRect xOff="0" yOff="0" xSize="4320" ySize="2160" />
<DstRect xOff="0" yOff="0" xSize="4320" ySize="2160" />
</SimpleSource>
</VRTRasterBand>
<VRTRasterBand dataType="Int16" band="2">
<Metadata>
<MDI key="NETCDF_DIM_time">1</MDI>
</Metadata>
<SimpleSource>
</SimpleSource>
</VRTRasterBand>
<VRTRasterBand dataType="Int16" band="3">
<Metadata>
<MDI key="NETCDF_DIM_time">2</MDI>
</Metadata>
<SimpleSource>
</SimpleSource>
</VRTRasterBand>
</VRTDataset>
<Metadata>
<MDI key="NETCDF_DIM_time_DEF">{0,6}</MDI>
<MDI key="NETCDF_DIM_time_VALUES">0</MDI>
</Metadata>
<Metadata>
</Metadata>
<SimpleSource>
</SimpleSource>
</VRTRasterBand>
<Metadata>
<MDI key="NETCDF_VARNAME">chl</MDI>
</Metadata>
<SimpleSource>
</SimpleSource>
</VRTRasterBand>
</VRTDataset>
