[gdal-dev] How to identify a point is belong to a polygon ?
Chaitanya kumar CH chaitanya.ch at gmail.com
Mon Jul 23 20:37:58 PDT 2012
Tai,
If your rebuild was successful with geos, the only reason for you to get
the error is that the application is accessing the wrong libraries
somewhere in your system. Do a clean rebuild and make sure the
LD_LIBRARY_PATH and GDAL_DATA are set correctly.
On Tue, Jul 24, 2012 at 7:37 AM, taibc <taibc_coltech at yahoo.com> wrote:
> Thanks Mateusz,
> I edited the nmake.opt by adding below lines:
> GEOS_DIR = C:/geos-3.3.5
> GEOS_LIB = $(GEOS_DIR)/src/geos_c_i.lib
> GEOS_CFLAGS = -I$(GEOS_DIR)/capi -I$(GEOS_DIR)/include/geos -DHAVE_GEOS
> Then, I rebuilt GDAL, but still got the error: "GEOS support not enable".
> Kind regards,
> Tai
> *From:* Mateusz Loskot [via OSGeo.org] <[hidden email]<http://user/SendEmail.jtp?type=node&node=4990235&i=0>
> *To:* taibc <[hidden email]<http://user/SendEmail.jtp?type=node&node=4990235&i=1>>
> *Sent:* Monday, July 23, 2012 5:56 PM
> *Subject:* Re: How to identify a point is belong to a polygon ?
>  On 23 July 2012 11:52, taibc <[hidden email]> wrote:
> > I installed GEOS succesfful, and copy file geos.dll into my project. But
> I
> > still got the error: "GEOS support not enable" when using the method
> > "Within"
> > Are there something wrongs ?
> You need to edit nmake.opt and rebuild GDAL.
> Check this thread:
> http://lists.osgeo.org/pipermail/gdal-dev/2010-March/023829.html
> Best regards,
> Mateusz Loskot, http://mateusz.loskot.net
> gdal-dev mailing list
> [hidden email]
>  If you reply to this email, your message will be added to the discussion
> below:
> http://osgeo-org.1560.n6.nabble.com/How-to-identify-a-point-is-belong-to-a-polygon-tp4989501p4990029.html
>  To unsubscribe from How to identify a point is belong to a polygon ?, click
> here.
> NAML<http://osgeo-org.1560.n6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
> View this message in context: Re: How to identify a point is belong to a
> polygon ?<http://osgeo-org.1560.n6.nabble.com/How-to-identify-a-point-is-belong-to-a-polygon-tp4989501p4990235.html>
> Sent from the GDAL - Dev mailing list archive<http://osgeo-org.1560.n6.nabble.com/GDAL-Dev-f3742093.html>at Nabble.com.
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120724/23da467c/attachment.html>
