[gdal-dev] encoding problem when reading DXF file
Dmitry Baryshnikov
polimax at mail.ru
Mon Jul 23 23:41:58 PDT 2012
24.07.2012 5:37, dequan chen ?????:
> hi all,
> I download the latest gdal-19-1600-core.msi from
> http://www.gisinternals.com/sdk and installed, then copy gdal_csharp.dll,
> ogr_csharp.dll, osr_csharp.dll etc to read .DXF file. But it has the
> problem
> of charactor encoding. My DXF file contains chinese charactor that code is
> GB2312. If i use DLLs from FWTOOLS, the charactor encoding correctly,
> but i
> cannot to run my compiled EXE (both debug and release versions). The
> application just crashes.
> What more work should i do ? thanks advanced.
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Hi Dequan,
It seems to me that is the similar issue
http://trac.osgeo.org/gdal/ticket/4650
Check TestCapability method of DXF driver
Best regards,
Dmitry
<http://trac.osgeo.org/gdal/wiki/TestCapability>
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120724/ed13d616/attachment-0001.html>
