[gdal-dev] Python Bindings - ReadArray direct to ctypes array?
Even Rouault
even.rouault at mines-paris.org
Sat Jul 28 02:17:31 PDT 2012
Le samedi 28 juillet 2012 05:40:57, Jay L. a écrit :
> List,
> I am working on a python script using the multiprocessing module with
> shared memory ctype arrays.
> Currently the workflow is to open the dataset and grab the first band, as
> usual. I then read in the array, create an empty ctype array, and use
> memmove to move the numpy array to my ctypes array.
> Is it possible, via python, to read the array direct to a ctypes array and
> bypass reading the array as an ndarray?
No, although it could certainly be extended to do so.
But with ctypes, you are able to bind all C functions of the GDAL API, so you
can try the following snippet. Of course, due to the nature of ctypes
bindings, you must be extra carefull of the value/size of arguments you use,
otherwise crashes can easily happen.
from ctypes import *
def getlibgdal():
import sys
# Might need name tweaking depending on platfrom & version
if sys.platform == 'win32':
libgdal = windll.LoadLibrary("gdal19.dll")
else:
libgdal = cdll.LoadLibrary("libgdal.so.1")
libgdal.GDALOpen.argtypes = [ c_char_p, c_int ]
libgdal.GDALOpen.restype = c_void_p
libgdal.GDALClose.argtypes = [ c_void_p ]
libgdal.GDALGetRasterCount.argtypes = [ c_void_p ]
libgdal.GDALGetRasterCount.res_type = c_int
libgdal.GDALGetRasterXSize.argtypes = [ c_void_p ]
libgdal.GDALGetRasterXSize.res_type = c_int
libgdal.GDALGetRasterYSize.argtypes = [ c_void_p ]
libgdal.GDALGetRasterYSize.res_type = c_int
libgdal.GDALGetRasterBand.argtypes = [ c_void_p, c_int ]
libgdal.GDALGetRasterBand.restype = c_void_p
libgdal.GA_ReadOnly = 0
libgdal.GA_Update = 1
libgdal.GF_Read = 0
libgdal.GF_Write = 1
libgdal.GDT_Unknown = 0
libgdal.GDT_Byte = 1
libgdal.GDT_UInt16 = 2
libgdal.GDT_Int16 = 3
libgdal.GDT_UInt32 = 4
libgdal.GDT_Int32 = 5
libgdal.GDT_Float32 = 6
libgdal.GDT_Float64 = 7
libgdal.GDT_CInt16 = 8
libgdal.GDT_CInt32 = 9
libgdal.GDT_CFloat32 = 10
libgdal.GDT_CFloat64 = 11
libgdal.GDALRasterIO.argtypes = [
c_void_p, # rasterband
c_int, # eRWFlag
c_int, # nXOff
c_int, # nYOff
c_int, # nXSize
c_int, # nYSize
c_void_p, # pData
c_int, # nBufXSize
c_int, # nBufYSize
c_int, # eBufType
c_int, # nPixelSpace
c_int ] # nLineSpace
libgdal.GDALRasterIO.res_type = c_int
# Don't forget to register all drivers
libgdal.GDALAllRegister()
return libgdal
libgdal = getlibgdal()
ds = libgdal.GDALOpen("byte.tif", libgdal.GA_ReadOnly)
if ds is 0:
import sys
sys.exit(1)
xsize = libgdal.GDALGetRasterXSize(ds)
ysize = libgdal.GDALGetRasterYSize(ds)
band = libgdal.GDALGetRasterBand(ds, 1)
ar = (c_byte * (xsize * ysize))()
ret = libgdal.GDALRasterIO(band, libgdal.GF_Read,
0, 0, xsize, ysize,
cast(ar, c_void_p),
xsize, ysize, libgdal.GDT_Byte,
0, 0)
if ret == 0:
print('success')
libgdal.GDALClose(ds)
> Thanks,
> J
