[gdal-dev] OSM Driver and World Planet file (pbf format)
Jukka Rahkonen
jukka.rahkonen at mmmtike.fi
Mon Jul 30 04:58:46 PDT 2012
Jukka Rahkonen <jukka.rahkonen <at> mmmtike.fi> writes:
> I borrowed my son's computer and made one more test. Important
numbers about the
> computer:
> Windows 7, 64 -bit
> Four-core Intel i5 2500k @3,3 GHz
> SSD disk
> Timings for germany.osm.pbf by using -lco SPATIAL_INDEX=NO. Times are
total
> times from the beginning of the test
> 70% progress - 5 minutes (I suppose resolving ways begins about at this phase)
> 100 % progress - 17 minutes
> manual index creation for all the layers ready - 45 minutes
> Results are interesting. Import to Spatialite without indexing was
six times
> faster for me and I suppose it is mostly because of the SSD drive.
But creating
> indexes took me 30 minutes while you timing was 22 minutes.
Perhaps there is
> something sub-optimal in combination of
Windows/Spatialite/Create spatial index.
> Anyway, the score for germany.osm.pbf is now 45 minutes. Someone
with Linux and
> SSD drive is perhaps the one to beat the record.
> For comparison, converting finland.osm.pbf took 2 min 40 sec.
Converting Germany
> took 20 times more time and I believe that the relation is OK now.
Another set of tests with a brand new and quite powerful laptop.
Specs for the
computer:
Intel i7-2760QM @2.4 GHz processor (8 threads)
Hitachi Travelstar Z7K320 7200 rpm SATA disk
8 GB of memory
Windows 7, 64-bit
GDAL-version r24717, Win64 build from gisinternals.com
Timings for germany.osm.pbf (1.3 GB)
A) Default settings with command
ogr2ogr -f sqlite -dsco spatialite=yes germany.sqlite
germany.osm.pbf -gt 20000 -progress --config OGR_SQLITE_SYNCHRONOUS OFF
- reading the data 67 minutes
- creating spatial indexes 38 minutes
- total 105 minutes
B) Using in-memory Spatialite db for the first step by giving
SET OSM_MAX_TMPFILE_SIZE=7000
- reading the data 16 minutes
- total 54 minutes
Peak memory usage during this conversion was 4.4 GB.
Conclusions
* The initial reading of data is heavily i/o bound. This phase
is really fast if there is enough memory for keeping the OSM
tempfile in memory but SSD disk seems to offer equally good
performance.
* Creating spatial indexes for the Spatialite tables is also
i/o bound. The hardware sets the speed limit and there are
no other tricks for improving the performance. Multi-core
CPU is quite idle during this phase with 10-15% load.
* If user does not plan to do spatial queries then then it
may be handy to save some time and create the Spatialite db
without spatial indexes by using -lco SPATIAL_INDEX=NO option.
* Windows disk i/o may be a limiting factor.
I consider that for small OSM datasets the speed starts to be
good enough. For me it is about the same if converting the
Finnish OSM data (137 MB in .pbf format) takes 160 or 140
seconds when using the default settings or in-memory temporary
database, respectively.
-Jukka Rahkonen-
