[gdal-dev] gdalbuildvrt problem with heterogenous band characteristics
Chaitanya kumar CH
chaitanya.ch at gmail.com
Tue Jul 31 06:30:17 PDT 2012
Casper,
This message should not appear unless there is a difference in the band
data type, colour interpretation or the band order.
Can you check if manually adding the old file works?
On Mon, Jul 30, 2012 at 11:01 PM, Casper Børgesen (CABO) <CABO at niras.dk>wrote:
> Hi! ****
> I’m trying to create a VRT file from 4 GeoTIFFs using gdalbuildvrt. Three
> of the GeoTIFFs are created using OrthoVista and the last one created with
> an earlier version of the same program. When I run gdalbuildvrt I get the
> following error message when I try to add the file created by the early
> version: ****
> Warning 6: gdalbuildvrt does not support heterogenous band
> characteristics. Skipping...****
> Running gdalinfo on the 4 files I see only a difference in the metadata
> section (and of course in the coordinates). ****
> In the following is the band information from two of the files:****
> [From new version]****
> Band 1 Block=6250x20 Type=Byte, ColorInterp=Red****
> Overviews: 1024x1024****
> Band 2 Block=6250x20 Type=Byte, ColorInterp=Green****
> Band 3 Block=6250x20 Type=Byte, ColorInterp=Blue****
> Band 4 Block=6250x20 Type=Byte, ColorInterp=Undefined****
> [From earlier version]****
> To me they seem identical and I can display them both using QGis 1.8. I
> guess that the difference is deeper inside the TIFFs than gdalinfo informs
> me about – what can I do to avoid this problem?****
> Regards Casper****
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120731/51ba0f30/attachment.html>
