[gdal-dev] gdal_translate takes negative values as an option (?)
Ivan Lucena
ivan.lucena at princeton-ma.us
Fri Jun 1 13:23:25 PDT 2012
That is great! Thanks Even.
> -------Original Message-------
> From: Even Rouault <even.rouault at mines-paris.org>
> To: gdal-dev at lists.osgeo.org, Ivan Lucena <ivan.lucena at princeton-ma.us>
> Subject: Re: [gdal-dev] gdal_translate takes negative values as an option (?)
> Sent: Jun 01 '12 15:10
> Le vendredi 01 juin 2012 17:17:46, Ivan Lucena a écrit :
> > It turns out that gdal_translate -scale doesn't parse exponential by using
> > the function ArgIsNumeric:
> > http://trac.osgeo.org/gdal/browser/trunk/gdal/apps/gdal_translate.cpp#L1258
> > It works fine with -0.0000000000000000000000000000000000034
> I've fixed ArgIsNumeric() in r24528, so values in scientific notation should now
> be recognized properly.
