[gdal-dev] Geospatial PDF with OGR_DATASOURCE
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Wed Jun 6 14:33:41 PDT 2012
Even Rouault wrote:
>> My styled test points are available at
>> http://latuviitta.org/documents/styled_pdf_points.gml
> The link does not work (the domain name has expired apparently), but I've
> successfully tested it with the following GML file :
I got the domain name back so the link should work again soon.
> Did you check that ogrinfo on your GML file reports lines with "Style =
> SYMBOL(something)" just before the geometry WKT ?
Oginfo is reporting like this
OGRFeature(pdf_piste2):0
fid (String) = pdf_piste2.0
OGR_STYLE (String) = SYMBOL(id:"ogr-sym-1",c:#000000,s:5)
Style = SYMBOL(id:"ogr-sym-1",c:#000000,s:5)
POINT (380530.90923728806 6677521.4394915262)
Data was as shapefile first and I converted it into GML with ogr2ogr. May have some little troubles with character encoding (shapefile must have been iso-8859-1) but ogrinfo does not look bad for me.
-Jukka-
> Even
