[gdal-dev] Compiling gdal with xlc
Shlomi Vaknin shlomivaknin at gmail.com
Thu Jun 7 02:08:54 PDT 2012
Hello,
I would like to know if anyone has any experience in compiling this library
over aix using xlc compiler (I will most likely not be able to use gcc, but
still not sure..)
what i specifically need from the library is to read dted files.
if you got any suggestions, any hint will help
thanks alot!
Shlomi
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120607/73e1e0d7/attachment.html>
