[gdal-dev] ogr2ogr does not project coordinates in csv file
Johann Hirner
johann.hirner at gmx.de
Fri Jun 8 07:37:07 PDT 2012
Dear list,
I am trying to transform a list of coordinates in a csv file from EPSG:4326 to a KML in UTM 32N (EPSG:32632). I am using this command:
ogr2ogr.exe -f KML -t_srs epsg:32632 out.kml 4326.vrt
However the output coordinates are not transformed (see output below). What is it that I am missing?
Kind regards
Johann
THe vrt file loooks like this:
<OGRVRTDataSource>
<OGRVRTLayer name="4326">
<SrcDataSource relativeToVRT="0">4326.csv</SrcDataSource>
<GeometryType>wkbPoint</GeometryType>
<GeometryField encoding="PointFromColumns" x="lon" y="lat"/>
<LayerSRS>EPSG:4326</LayerSRS>
</OGRVRTLayer>
</OGRVRTDataSource>
The csv file looks like this:
P, lon, lat
1, 6.219200, 46.572210
2, 9.345943, 46.605497
3, 9.330450, 44.000110
4, 6.343561, 43.969698
The resulting kml file:
<?xml version="1.0" encoding="utf-8" ?>
<kml xmlns="http://www.opengis.net/kml/2.2">
<Document><Folder><name>4326</name>
<Schema name="4326" id="4326">
<SimpleField name="Name" type="string"></SimpleField>
<SimpleField name="Description" type="string"></SimpleField>
<SimpleField name="P" type="string"></SimpleField>
<SimpleField name="lon" type="string"></SimpleField>
<SimpleField name="lat" type="string"></SimpleField>
</Schema>
<Placemark>
<ExtendedData><SchemaData schemaUrl="#4326">
<SimpleData name="P">1</SimpleData>
<SimpleData name="lon">6.219200</SimpleData>
<SimpleData name="lat">46.572210</SimpleData>
</SchemaData></ExtendedData>
<Point><coordinates>6.219199999982147,46.572209999958666</coordinates></Point>
</Placemark>
<Placemark>
<SimpleData name="P">2</SimpleData>
<SimpleData name="lon">9.345943</SimpleData>
<SimpleData name="lat">46.605497</SimpleData>
<Point><coordinates>9.345943,46.605497</coordinates></Point>
</Placemark>
<Placemark>
<SimpleData name="P">3</SimpleData>
<SimpleData name="lon">9.330450</SimpleData>
<SimpleData name="lat">44.000110</SimpleData>
<Point><coordinates>9.33045,44.00011</coordinates></Point>
</Placemark>
<Placemark>
<SimpleData name="P">4</SimpleData>
<SimpleData name="lon">6.343561</SimpleData>
<SimpleData name="lat">43.969698</SimpleData>
<Point><coordinates>6.343560999981887,43.96969799997111</coordinates></Point>
</Placemark>
</Folder></Document></kml>
NEU: FreePhone 3-fach-Flat mit kostenlosem Smartphone!
Jetzt informieren: http://mobile.1und1.de/?ac=OM.PW.PW003K20328T7073a
