[gdal-dev] gdalwarp incomplete output with geostationary satellite projection
Marcel Derrien
marcel.derrien at meteo.fr
Mon Jun 11 09:10:58 PDT 2012
Hi all,
I am using gdalwarp (1.9.0, Linux x86_64) to reproject data from Plate
carre projection to the target Geostationary Satellite projection
(proj.4 definition) in an image defined by its georeferenced extent and
resolution (target georeferenced units, metres).
The output image is as expected but the earth disk is not completely
filled when approaching the poles.
During execution the following error messages are output:
ERROR 1: tolerance condition error
ERROR 1: Reprojection failed, err = -20, further errors will be
supressed on the transform object.
Here is the command I am using:
gdalwarp -t_srs "+proj=geos +a=6378169 +b=6356583.8 +lon_0=0
+h=35785831" -tr 3000.403357 3000.403357 -te -5570248.832537
-5567248.428647 5567248.428647 5570248.832537 source.tif dest.tif
Has anyone an idea to obtain a full coverage of the earth disk ?
Thanks in advance,
Marcel Derrien
Type: text/x-vcard
Desc: not available
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120611/2bd5b924/attachment.vcf>
