[gdal-dev] reproject python numpy binary swath/lat/lon
Rutger
kassies at gmail.com
Tue Jun 12 05:29:45 PDT 2012
Etienne Tourigny-3 wrote
> To use geolocation arrays with gdalwarp you probably need to add the
> -geoloc argument
Its probably good to do so. I think however that if you use the VRT method
as shown at the link in the opening post, the "<Metadata
domain="GEOLOCATION">" part already takes care of this. Adding or removing
-geoloc doesnt make a difference when i use the VRT method, both work.
When using for example HDF files which have a lat/lon band its probably
mandatory, since its not obvious that you want them to be used for
geolocation.
View this message in context: http://osgeo-org.1560.n6.nabble.com/gdal-dev-reproject-python-numpy-binary-swath-lat-lon-tp4978609p4980774.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
