[gdal-dev] Reading NetCDF using VB.NET
Siebe Bosch
siebe at hydroconsult.nl
Thu Jun 14 10:08:20 PDT 2012
Hello all,
I'm trying to build a command line application in VB.NET that extracts
parts from a NetCDF file.
For this I'm using the C# API as supplied with FWTools version 2.4.7.
It's supposed to support VB.NET as well; am I right?
However, the application already crashes at the line Call GDAL.Registerall()
Here's the code:
Imports System
Imports OSGeo.GDAL
Imports OSGeo.OGR
Module MeteoBase
'Copyright Siebe Bosch Hydroconsult, 2012
'Lulofsstraat 55, unit 47 Den Haag, The Netherlands
'this program creates subsets from precipitation data in NetCDF-files
'as requested by the user. The program is designed to be called from
'a PHP-script.
Dim FileName As String
Dim ds As Dataset
Sub Main()
Dim DebugMode As Boolean
Console.WriteLine("This program extracts data from a NetCDF file")
Console.WriteLine("Path to the NetCDF file (*.cn)")
DebugMode = True
'start reading the command line arguments
If DebugMode Then
FileName = "c:\GDAL\PM\1990\EVAP_PM_19901231.nc"
Else
If My.Application.CommandLineArgs.Count = 0 Then
Console.WriteLine("Enter the path to the NetCDF-file:")
FileName = Console.ReadLine()
ElseIf My.Application.CommandLineArgs.Count <> 1 Then
Console.WriteLine("Error: incorrect number of arguments presented")
Else
FileName = My.Application.CommandLineArgs(0)
End If
End If
Try
'start reading the NetCDF File
Call Gdal.AllRegister()
ds = Gdal.Open(FileName, Access.GA_ReadOnly)
If ds Is Nothing Then
Console.WriteLine("Cannot open NetCDF file: " & FileName)
Throw New Exception
Else
Console.WriteLine("Raster dataset parameters:")
Console.WriteLine(" Projection: " + ds.GetProjectionRef())
Console.WriteLine(" RasterCount: " + ds.RasterCount)
Console.WriteLine(" RasterSize (" + ds.RasterXSize + "," +
ds.RasterYSize + ")")
End If
Catch ex As Exception
Console.WriteLine("Error in sub Main of Meteobase")
End Try
End Sub
End Module
