[gdal-dev] GDAL Byte Swapping?
Trist, Brenda R.
BRENDA.R.TRIST at saic.com
Thu Jun 14 12:26:09 PDT 2012
I am new to GDAL. I recently downloaded GDAL have successfully built
and linked to the source. The program I am writing reads in a
GeoTiff DEM (32bit format) and writes the dem data portion out to a
ntif file (using NITRO NITF routines from sourceforge).
I then ran the command od -c on the tif file I am reading and on the
ntif I just created to compare the DEM data area. I noticed that
while the data is there that the bytes appear to have been swapped.
I am assuming that I don't want it to do that. I was wondering if
anyone has encountered this same thing and if there is something that
I should be doing differently? I researched the bug list and all
mentions of byteswapping pretty much have been closed due to being
fixed. So I am assuming that I must be doing something wrong at my end.
Thank you,
Becky Trist
SAIC
100 Rialto Place, Suite 200
Melbourne, FL 32901
321-751-3236
"Sometimes you have to look reality in the eye, and deny it." -
Garrison Keillor
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120614/55169f44/attachment.html>
