[gdal-dev] convert .tif/.tfwx/.aux.xml to a geotiff?
Jean-Claude Repetto
jrepetto at free.fr
Sat Jun 16 07:25:31 PDT 2012
On 06/15/2012 04:46 PM, Martin Ouellet wrote:
> Hi,
> I manually georeferenced some images in ArcGIS and at the end, I got a
> .tfwx file and a aux.xml.
> I wish to convert them into geotiff with the georeferenced info in the
> header:
> 1) I've renamed the .tfwx into .tfw and run a gdal_translate. The
> command didn't failed but the resulting image is not georeferenced at all
> Is it possible to do that perhaps using the info in the .aux.xml file?
> Thanks,
> MartinO
Hello Martin,
Could you post here the contents of the .tfwx and .aux.xml files ?
Jean-Claude
