[gdal-dev] How to use RPC Metadata from NITF Files in a MapServer TileIndex
Even Rouault
even.rouault at mines-paris.org
Sun Jun 17 09:55:00 PDT 2012
Le dimanche 17 juin 2012 18:45:01, Smith, Michael ERDC-RDE-CRREL-NH a écrit :
> I did originally use -dstalpha. I had dropped it when creating the
> geotiffs as I used PHOTOMETRIC=YCBCR as a creation option.
> I'll try with -dstalpha and dropping the YCBCR.
Ah, ok, JPEG compression is indeed incompatible with alpha band. But you could
however use a mask band, which recent MapServer should handle.
gdalwarp rpc -of vrt -overwrite -t_srs epsg:3857 -r cubic --config
GDAL_CACHEMAX 500 -wm 500 $1 $1.vrt -dstalpha
gdal_translate -b 1 -b 2 -b 3 -mask 4 -co "TILED=YES" -co "JPEG_QUALITY=95" -
co "COMPRESS=JPEG" -co "PHOTOMETRIC=YCBCR" $1.vrt $1.tif
gdaladdo --config COMPRESS_OVERVIEW JPEG --config PHOTOMETRIC_OVERVIEW
YCBCR --config INTERLEAVE_OVERVIEW PIXEL $1.tif 2 4 8 16 32
> Is there a known issue with using the vrts inside a tileindex that makes
> it so slow?
RPC reprojection is probably slow, and VRT can add some overhead, especially
if the tiling scheme it adopts (128x128 blocks) is very different from the
source raster. Furthermore, if you make a request that is a zoom out, the VRT
cannot benefit from overviews of the source raster and will make reprojection
at full scale, before zooming out.
