[gdal-dev] MSSQL Spatial and UTF-8
Jukka Rahkonen jukka.rahkonen at mmmtike.fi
Tue Jun 19 11:08:29 PDT 2012
Gunter Becker <gunter.becker <at> csogis.de> writes:
> Hi,
> I'm trying to import a shapefile via ogr2ogr into a SQL Server 2008 DB. When
> looking at the created table I realised that some columns have some ugly
> columnnames. Same to the strings in the data of this table. The problem is
> caused by some special characters (german umlauts) in the dataset.
> Using ogr2ogr with other drivers (ex. SQLite, PostGIS) to import this
> shapefile works as expected so that I think it is a problem with the "MSSQL
> Spatial"-driver.
> Is there any driver related setting I can make to force UTF-8 import into
> SQL Server?
You can try if setting SHAPE_ENCODING environment variable to suit your
shapefile before running ogr2ogr helps. It did help me couple of days ago with
Spatialite.
-Jukka Rahkonen-
