[gdal-dev] [gdal_translate] Spatial subset HDF4Image with multiple subdatasets?
dcd dennis.duro at glel.carleton.ca
Wed Jun 20 05:50:29 PDT 2012
Le mardi 19 juin 2012 23:55:49, dcd a écrit :
> Hi,
> Is it possible to spatially subset an HDF4Image that contains multiple
> subdatasets using gdal_translate (GDAL 1.9.1)? When using a spatial subset
> switch ("-a_ullr"), I get the following response:
> "Input file contains subdatasets. Please, select one of them for reading."
> This happens regardless of output format specified (HDF4Image, GTiff,
> ENVI,
> etc.), or whether the "-b" switch has been used as per the examples here:
> http://www.gdal.org/gdal_translate.html. A workaround is to use the "-sds"
> switch allows the process to complete, but (as expected) it processes each
> subdataset as a separate file. I suppose I can just merge these
> subdatasets
> together again, but I'd like to avoid the extra step. Is this possible?
> I'm working with a MODIS imagery (MOD09GA), but I've had the issues with
> other similar HDF4 datasets.
You can use one of the subdataset names listed by gdalinfo on the HDF file
as a
pseudo-filename usable by any GDAL utility (including gdal_translate).
For example :
$ gdalinfo MOD02HKM.A2011169.1750.005.NRT.hdf
Subdatasets:
SUBDATASET_1_NAME=HDF4_EOS:EOS_SWATH:"MOD02HKM.A2011169.1750.005.NRT.hdf":MODIS_SWATH_Type_L1B:EV_500_RefSB
  SUBDATASET_1_DESC=[5x4060x2708] EV_500_RefSB MODIS_SWATH_Type_L1B (16-bit
unsigned integer)
SUBDATASET_2_NAME=HDF4_EOS:EOS_SWATH:"MOD02HKM.A2011169.1750.005.NRT.hdf":MODIS_SWATH_Type_L1B:EV_500_RefSB_Uncert_Indexes
  SUBDATASET_2_DESC=[5x4060x2708] EV_500_RefSB_Uncert_Indexes
MODIS_SWATH_Type_L1B (8-bit unsigned integer)
$ gdalinfo
Driver: HDF4Image/HDF4 Dataset
Files: MOD02HKM.A2011169.1750.005.NRT.hdf
Size is 2708, 4060
Coordinate System is `'
GCP Projection =
GEOGCS["WGS 84",
    DATUM["WGS_1984",
        SPHEROID["WGS 84",6378137,298.257223563,
            AUTHORITY["EPSG","7030"]],
        TOWGS84[0,0,0,0,0,0,0],
        AUTHORITY["EPSG","6326"]],
    PRIMEM["Greenwich",0,
        AUTHORITY["EPSG","8901"]],
    UNIT["degree",0.0174532925199433,
        AUTHORITY["EPSG","9108"]],
    AUTHORITY["EPSG","4326"]]
Merci beaucoup for the quick reply!
Sorry, I didn't mention in the original post that I need to spatially subset
hundreds of images.
While I know that I can declare subdatasets individually, it will still mean
that I need to combine the individual subdatasets after spatial subsetting.
Also, declaring individual subdatasets by name is a bit of pain, although
doable if need be.
It would be nice if the "-b" switch in gdal_translate could be used for
selecting specific subdatasets within an HDF4Image, either by their full
name (SUBDATASET_1_NAME=....), description (SUBDATASET_1_DESC=...), or
preferably by index ("-b 1" would be equivalent to "SUBDATASET_1", "-b 2"
would be equivalent to "SUBDATASET_2", etc). When reading the gdal_translate
documentation for the "-b" switch, it appears that this should be possible,
although the example is with a GTiff image. If it is possible with HDF
files, I'd like to know how. If not, I will put in a request using the
appropriate channels.
I could always use the MODIS Reprojection Tool to script this task, but I'd
like to have done this exclusively using GDAL.
Anyway, thanks for the tip!
View this message in context: http://osgeo-org.1560.n6.nabble.com/gdal-translate-Spatial-subset-HDF4Image-with-multiple-subdatasets-tp4982526p4982668.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
