[gdal-dev] Updating shapefile "fields" name with ogr2ogr
Eli Adam
eadam at co.lincoln.or.us
Fri Jun 22 08:55:39 PDT 2012
I've also found this very confusing and unexpected. Once I did figure
it out it has been very useful. Could
ogrinfo CHEMIN.shp -sql "ALTER TABLE CHEMIN RENAME COLUMN prec_alti TO foo"
or similar be added as an example to http://gdal.org/ogrinfo.html and
perhaps also as a 'note about ogrinfo with OGR SQL' on
http://gdal.org/ogr/ogr_sql.html?
Perhaps http://gdal.org/ogr/ogr_sql.html could be updated from:
-sql statement:
Execute the indicated SQL statement and return the result.
to something like:
-sql statement:
Execute the indicated SQL statement and return the result. In
place updates (ALTER TABLE) are also permitted.
Eli
On Thu, Jun 21, 2012 at 11:03 PM, Hermann Peifer <peifer at gmx.eu> wrote:
> On 2012-06-20 19:50, Even Rouault wrote:
>> I know this is going to sound a bit counter-intutive at first...
>> ogrinfo opens datasources in read/write mode by default...
> Just out of curiosity: why does an ...info tool use read/write mode by
> default? One would expect that it only needs to *read* some info in the data
> source?
> Hermann
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
