[gdal-dev] gdaltransform with gcps from file
Brent Fraser bfraser at geoanalytic.com
Sat Jun 23 09:10:22 PDT 2012
Jan,
   Dunno about using the <srcfile> parameter in gdaltransform, but while
using gdal_translate, I have used the "--optfile" option and put
multiple "-gcp" commands in it. Perhaps it would work with gdaltransform
too...
Best Regards,
Brent Fraser
On 6/23/2012 6:23 AM, Jan Hartmann wrote:
> Silly question, perhaps. I use gdaltransform with gcps given at the
> command line. According to the documentation, gcps can also be put
> into the <srcfile> parameter to the program. What is the format of
> that file? Most of the time I get an error message like "file fomat
> not supported". With four numbers per line the message is "Ungridded
> dataset". What am I doing wrong?
> Jan
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
URL: <http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120623/9a44adc5/attachment.html>
