[gdal-dev] Building from source on 64 bit environment
kedardeshpande87
kedardeshpande87 at gmail.com
Wed Jun 27 11:36:03 PDT 2012
I am trying to build the gdal from source on a 64 bit RHEL5. I am also using
the swig bindings for Java.
But I am getting UnsatisfiedLinkError with the error cause as :
.../libogrjni.so: wrong ELF class: ELFCLASS64* (Possible cause: architecture
word width mismatch)*
Where can I set this option of 32/64 bit so as to run it on 64 bit linux
machine ? Is there any variable defined in any build file ?
Thanks,
Kedar
View this message in context: http://osgeo-org.1560.n6.nabble.com/Building-from-source-on-64-bit-environment-tp4984334.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
