[gdal-dev] [saga-gis-developer] the output image is cut to half
Salvatore Larosa lrssvtml at gmail.com
Thu Jun 28 01:11:22 PDT 2012
I think this could be the cause of my problem with output saga images!
Any idea on how avoid libtiff version mismatch?
I refer at 1.9.1 version!
Il giorno gio, 28/06/2012 alle 09.35 +0200, Volker Wichmann ha scritto:
> Hi Salvatore,
> On 06/27/2012 03:29 PM, Salvatore Larosa wrote:
> >> "Warning 1: libtiff version mismatch : You're linking against libtiff
> >> 3.X, but GDAL has been compiled against libtiff >= 4.0.0"
> > Actually I have some problem with libtiff. I compiled gdal with external
> > libtiff I recompiled saga and now:
> > # ldd libgdal.so | grep libtiff
> > 	libtiff.so.4 => /usr/lib/x86_64-linux-gnu/libtiff.so.4
> > (0x00007f46ec898000)
> > # ldd libio_gdal.so | grep libtiff
> > (0x00007f07608ce000)
> > both the versions are matching!
> > But I still get thr Warning message!
> I think this is a GDAL issue, the message is actually printed from
> ./frmts/gtiff/geotiff.cpp:                     "libtiff version mismatch
> : You're linking against libtiff 3.X, but GDAL has been compiled against
> libtiff >= 4.0.0");
> In the file, line 9110, there is also a comment:
> /* This is a frequent configuration error that is difficult to track down */
> /* for people unaware of the issue : GDAL built against internal libtiff
> (4.X) */
> /* but used by an application that links with external libtiff (3.X) */
> /* Note: on my conf, the order that cause GDAL to crash - and that is
> detected */
> /* by the following code - is "-ltiff -lgdal". "-lgdal -ltiff" works for
> the */
> /* GTiff driver but probably breaks the application that believes it
> uses libtiff 3.X */
> /* but we cannot detect that... */
> In the news file there are further hints:
> ./NEWS: * Don't prevent from loading GTiff driver even if libtiff
> version mismatch detected (#4101)
> ./NEWS: * Try to detect build-time vs runtime libtiff version mismatch
> (*nix only)
> I would guess that you still observe this conflict,
> best regards,
> Volker
> Live Security Virtual Conference
> Exclusive live event will cover all the ways today's security and
> threat landscape has changed and how IT managers can respond. Discussions
> will include endpoint security, mobile security and the latest in malware
> threats. http://www.accelacomm.com/jaw/sfrnl04242012/114/50122263/
> saga-gis-developer mailing list
> saga-gis-developer at lists.sourceforge.net
> https://lists.sourceforge.net/lists/listinfo/saga-gis-developer
Salvatore Larosa
linkedIn: http://linkedin.com/in/larosasalvatore
twitter: @lrssvt
skype: s.larosa
IRC: lrssvt on freenode
