[gdal-dev] Possibility to add a MorphFromESRI-like feature to gdalwarp ?
Etienne Tourigny
etourigny.dev at gmail.com
Fri Jun 29 07:08:41 PDT 2012
It's a shame that it's not done automatically, but it's hard to
differentiate ESRI WKT definitions from OGC ones without searching all
parameters for known ESRI keywords.
However, if the WKT is inside a .prj file (as part of a shapefile), I
think the OGR Shapefile driver does do the morphFromESRI automatically
On Fri, Jun 29, 2012 at 11:03 AM, Matthieu Rigal <rigal at rapideye.net> wrote:
> Brilliant ! I am sorry, I had never seen that possibility. But it works
> perfectly.
> Thanks again Etienne,
> Matthieu
> On Fri, Jun 29, 2012 at 3:30 PM, Etienne Tourigny <etourigny.dev at gmail.com>
> wrote:
>> As referenced in SetFromUserInput [1] you can force a morphFromESRI by
>> prefixing a WKT definition (file or WKT string) with "ESRI::"
>> I'm pretty sure that gdalwarp uses SetFromUserInput to get the SRS
>> definition.
>> [1]
>> http://www.gdal.org/ogr/classOGRSpatialReference.html#aec3c6a49533fe457ddc763d699ff8796
>> On Fri, Jun 29, 2012 at 7:09 AM, Matthieu Rigal <rigal at rapideye.net>
>> wrote:
>> > Hi guys,
>> > When asking gdalwarp to warp from a WKT projection generated by ESRI, it
>> > will fail when attempting to convert it to Proj4 (ex:
>> > Lambert_Conform_Conic
>> > projections).
>> > Wouldn't it be possible to integrate some check/transformation like the
>> > one
>> > done in Python here :
>> > http://nullege.com/codes/search/osgeo.osr.SpatialReference.MorphFromESRI
>> > Sorry, I am not a C++ dev and I won't be able to contribute...
>> > Regards,
>> > Matthieu
> RapidEye AG
> Molkenmarkt 30
> 14776 Brandenburg an der Havel
> Germany
> Follow us on Twitter! www.twitter.com/rapideye_global
> Head Office/Sitz der Gesellschaft: Brandenburg an der Havel
> Management Board/Vorstand: Ryan Johnson
> Chairman of Supervisory Board/Vorsitzender des Aufsichtsrates: Robert
> Johnson
> Commercial Register/Handelsregister Potsdam HRB 24742 P
> Tax Number/Steuernummer: 048/100/00320
> VAT-Ident-Number/Ust.-ID: DE 815303842
> DIN EN ISO 9001 certified
