[gdal-dev] drawing line using OGR and mysql in mapserver
Chaitanya kumar CH chaitanya.ch at gmail.com
Fri Mar 2 08:09:14 EST 2012
Murat,
Can you show a sample output of your view?
SELECT * FROM geom;
On Fri, Mar 2, 2012 at 6:12 PM, Murat Beyhan <beyhan at deprem.gov.tr> wrote:
> Dear Chaitanya,
> I see what you explain first I convert lat lon data to string then I
> concatenate them to string again. But I would like to ask
> I have already add data to mysql table as follows is this also correct
> because when I browse table it seems it store data in geometry field
> but mapserver gives error
> Unable to identify source field 'fault' for geometry.
> any way
> I will try to convert data first then I can return back you.
> Regards...
> ps.
> ogrinfo
> MYSQL:dynamic,user=root,password=mysql_123,host=localhost,port=3306,tables=geom
> INFO: Open of
> `MYSQL:dynamic,user=root,password=mysql_123,host=localhost,port=3306,tables=geom'
>      using driver `MySQL' successful.
> 1: geom (None)
> it say none in geom
> may be first I have to do what you say
> thanks
> Murat
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120302/b87a8f71/attachment.html
