[gdal-dev] drawing line using OGR and mysql in mapserver
Murat Beyhan
beyhan at deprem.gov.tr
Fri Mar 2 10:27:45 EST 2012
Chaitanya,
What do you prefer and which way more fast to draw line and point
because I also draw point about 160000 and I use wkbpoint.
Any way how to change and What I will change in the vrt.
could you tell something about it
thanks
On Fri, 2012-03-02 at 20:23 +0530, Chaitanya kumar CH wrote:
> Murat,
> You specified the encoding for GeometryField in the VRT as WKT. OGR
> expects a WKT if you do that. Either change the data or the VRT.
> On Fri, Mar 2, 2012 at 6:42 PM, Murat Beyhan <beyhan at deprem.gov.tr>
> wrote:
> I have to say this is not view
> this is a table created.
> Because I could not declare type of geom field as a string
> than I create
> geometry field column in spatial mysql database..
> On Fri, 2012-03-02 at 18:39 +0530, Chaitanya kumar CH wrote:
> > Murat,
> > Can you show a sample output of your view?
> > SELECT * FROM geom;
> > On Fri, Mar 2, 2012 at 6:12 PM, Murat Beyhan
> > wrote:
> > Dear Chaitanya,
> > I see what you explain first I convert lat lon data
> to string
> > then I
> > concatenate them to string again. But I would like
> to ask
> > I have already add data to mysql table as follows is
> this also
> > correct
> > because when I browse table it seems it store data
> in geometry
> > field
> > but mapserver gives error
> > Unable to identify source field 'fault' for
> geometry.
> > any way
> > I will try to convert data first then I can return
> back you.
> > Regards...
> > ps.
> > ogrinfo
> MYSQL:dynamic,user=root,password=mysql_123,host=localhost,port=3306,tables=geom
> > INFO: Open of
> `MYSQL:dynamic,user=root,password=mysql_123,host=localhost,port=3306,tables=geom'
> > using driver `MySQL' successful.
> > 1: geom (None)
> > it say none in geom
> > may be first I have to do what you say
> > thanks
> > Murat
> > Best regards,
> > Chaitanya kumar CH.
> > +91-9494447584
> > 17.2416N 80.1426E
> > This message has been scanned for viruses and
> > dangerous content by MailScanner, and is
> > believed to be clean.
> Murat BEYHAN
> Jeofizik Y.Müh.
> T.C. Başbakanlık
> Afet ve Acil Durum Yönetimi Başkanlığı
> Deprem Dairesi Başkanlığı
> Eskişehir Yolu 12. Km.
> Lodumlu/ANKARA
> Tel: 312 2872680-1556
> email:beyhan at deprem.gov.tr
> Best regards,
> Chaitanya kumar CH.
> +91-9494447584
> 17.2416N 80.1426E
Murat BEYHAN
Jeofizik Y.Müh.
T.C. Başbakanlık
Lodumlu/ANKARA
