[gdal-dev] drawing line using OGR and mysql in mapserver
Murat Beyhan beyhan at deprem.gov.tr
Fri Mar 2 10:54:34 EST 2012
Chaitanya,
I store data in table not view as I told you before becasue I could not
declare column as string, then I create a new table and select
fault(line) column as linestring. in mysql WKT support these format
      * A LineString with four points:
        LINESTRING(0 0, 10 10, 20 25, 50 60)
        Note that point coordinate pairs are separated by commas.
      * A Polygon with one exterior ring and one interior ring:
        POLYGON((0 0,10 0,10 10,0 10,0 0),(5 5,7 5,7 7,5 7, 5 5))
      * A MultiPoint with three Point values:
        MULTIPOINT(0 0, 20 20, 60 60)
      * A MultiLineString with two LineString values:
        MULTILINESTRING((10 10, 20 20), (15 15, 30 15))
      * A MultiPolygon with two Polygon values:
        MULTIPOLYGON(((0 0,10 0,10 10,0 10,0 0)),((5 5,7 5,7 7,5 7, 5 5)))
      * A GeometryCollection consisting of two Point values and one
        LineString:
        GEOMETRYCOLLECTION(POINT(10 10), POINT(30 30), LINESTRING(15 15, 20 20))
How to modify wkt geometry  in string format
in map file it is already defined as
<GeometryType>wkbLineString</GeometryType>
like this.
I really sorry for giving trouble to you. Thanks
murat
On Fri, 2012-03-02 at 21:19 +0530, Chaitanya kumar CH wrote:
> Modify the table to store the line as a wkt geometry in string format.
> On Fri, Mar 2, 2012 at 9:12 PM, Murat Beyhan <beyhan at deprem.gov.tr>
> wrote:
>         Chaitanya,
>         I mean What should I do,
>         Still could not draw a simple line on the map,
>         Please how can I overcome this issue. How can I change VRT
>         file.
>         in order to read data from such table storing data as
>         linestring
>         regards
>         murat
>         On Fri, 2012-03-02 at 21:08 +0530, Chaitanya kumar CH wrote:
>         > I was talking about the geometry format of the line. You
>         have to
>         > decide for yourselves about the efficiency.
>         > On Fri, Mar 2, 2012 at 8:57 PM, Murat Beyhan
>         > wrote:
>         >         Chaitanya,
>         >         What do you prefer and which way more fast to draw
>         line and
>         >         point
>         >         because I also draw point about 160000 and I use
>         wkbpoint.
>         >         Any way how to change and What I will change in the
>         vrt.
>         >         could you tell something about it
>         >         thanks
>         >         On Fri, 2012-03-02 at 20:23 +0530, Chaitanya kumar
>         CH wrote:
>         >         > Murat,
>         >         > You specified the encoding for GeometryField in
>         the VRT as
>         >         WKT. OGR
>         >         > expects a WKT if you do that. Either change the
>         data or the
>         >         VRT.
>         >         > On Fri, Mar 2, 2012 at 6:42 PM, Murat Beyhan
>         >         > wrote:
>         >         >         I have to say this is not view
>         >         >         this is a table created.
>         >         >         Because I could not declare type of geom
>         field as a
>         >         string
>         >         >         than I create
>         >         >         geometry field column in spatial mysql
>         database..
>         >         >         On Fri, 2012-03-02 at 18:39 +0530,
>         Chaitanya kumar
>         >         CH wrote:
>         >         >         > Murat,
>         >         >         > Can you show a sample output of your
>         view?
>         >         >         > SELECT * FROM geom;
>         >         >         > On Fri, Mar 2, 2012 at 6:12 PM, Murat
>         Beyhan
>         >         >         > wrote:
>         >         >         >         Dear Chaitanya,
>         >         >         >         I see what you explain first I
>         convert lat
>         >         lon data
>         >         >         to string
>         >         >         >         then I
>         >         >         >         concatenate them to string
>         again. But I
>         >         would like
>         >         >         to ask
>         >         >         >         I have already add data to mysql
>         table as
>         >         follows is
>         >         >         this also
>         >         >         >         correct
>         >         >         >         because when I browse table it
>         seems it
>         >         store data
>         >         >         in geometry
>         >         >         >         field
>         >         >         >         but mapserver gives error
>         >         >         >         Unable to identify source field
>         'fault'
>         >         for
>         >         >         geometry.
>         >         >         >         any way
>         >         >         >         I will try to convert data first
>         then I
>         >         can return
>         >         >         back you.
>         >         >         >         Regards...
>         >         >         >         ps.
>         >         >         >         ogrinfo
>         MYSQL:dynamic,user=root,password=mysql_123,host=localhost,port=3306,tables=geom
>         >         >         >         INFO: Open of
>         `MYSQL:dynamic,user=root,password=mysql_123,host=localhost,port=3306,tables=geom'
>         >         >         >              using driver `MySQL'
>         successful.
>         >         >         >         1: geom (None)
>         >         >         >         it say none in geom
>         >         >         >         may be first I have to do what
>         you say
>         >         >         >         thanks
>         >         >         >         Murat
>         >         >         > Best regards,
>         >         >         > Chaitanya kumar CH.
>         >         >         > +91-9494447584
>         >         >         > 17.2416N 80.1426E
>         >         >         > This message has been scanned for
>         viruses and
>         >         >         > dangerous content by MailScanner, and is
>         >         >         > believed to be clean.
>         >         >         Murat BEYHAN
>         >         >         Jeofizik Y.Müh.
>         >         >         T.C. Başbakanlık
>         >         >         Afet ve Acil Durum Yönetimi Başkanlığı
>         >         >         Deprem Dairesi Başkanlığı
>         >         >         Eskişehir Yolu 12. Km.
>         >         >         Lodumlu/ANKARA
>         >         >         Tel: 312 2872680-1556
>         >         >         email:beyhan at deprem.gov.tr
>         >         >         This message has been scanned for viruses
>         and
>         >         > Best regards,
>         >         > Chaitanya kumar CH.
>         >         > +91-9494447584
>         >         > 17.2416N 80.1426E
>         >         > This message has been scanned for viruses and
>         >         Murat BEYHAN
>         >         Jeofizik Y.Müh.
>         >         T.C. Başbakanlık
>         >         Lodumlu/ANKARA
>         > Best regards,
>         > Chaitanya kumar CH.
>         > +91-9494447584
>         > 17.2416N 80.1426E
>         Murat BEYHAN
>         Geophysical Engineer, M.Sc.
>         Prime Ministry
>         Disaster and Emergency Management Presidency
>         Earthquake Department
>         Address: Eskisehir Yolu 12. Km.
>         Lodumlu/ANKARA
> Best regards,
> Chaitanya kumar CH.
> +91-9494447584
> 17.2416N 80.1426E
Murat BEYHAN
Jeofizik Y.Müh.
T.C. Başbakanlık
Lodumlu/ANKARA
