[gdal-dev] reading NOAA-19 AVHRR
Even Rouault
even.rouault at mines-paris.org
Tue Mar 6 14:33:33 EST 2012
Le mardi 06 mars 2012 16:06:16, Andrew Brooks a écrit :
> On 28 February 2012 16:06, Even Rouault <even.rouault at mines-paris.org>wrote:
> > I've skimmed quickly through the driver code and if you are lucky, it is
> > probably just a matter of changing a few lines (well, I can be wrong).
> Even
> I've produced a new patch for the satellite IDs based on the documentation.
> (diff -c from the 1.9.0 source)
Andrew,
Please create a Trac ticket with the patch so it doesn't get lost
> Andrew
