[gdal-dev] GDALOpen failed on GRC grid
mladen-g at distributel.net
Wed Mar 14 10:53:14 EDT 2012
I did some more research, and compared a working grid against the one
that fails to open. Here is the working grid, which is almost exactly
the same as the failing one (~50K difference in file sizes):
http://dl.dropbox.com/u/53500018/WorkingGdalOpen.zip
Comparing the two in a binary editor, I see differences in bytes 10
and 26 of the header... not sure exactly what that means without the
GRC spec (would anyone have a link for that, by the way?).
However, as I said in my original mail, the failing grid does open
correctly in other software (MapInfo and Global Mapper 13), so I
suspect that there may be a bug in the GDAL GRC driver. I guess that
opening a ticket is appropriate here, unless someone has other ideas?
Regards,
Mladen
Quoting mladen-g at distributel.net:
> Hello all,
> I'm experiencing an error when trying to open a GRC grid (Northwood
> VerticalMapper Classified Grid) with gdal_translate. The command
> and error is:
> C:\>gdal_translate -of vrt
> "C:\temp\ClassficationGrid-UK-Technologies_1.grc"
> "C:\temp\ClassficationGrid-UK-Technologies_1.vrt"
> ERROR 4: `C:\temp\ClassficationGrid-UK-Technologies_1.grc' not
> recognised as a supported file format.
> GDALOpen failed - 4
> This seems like it could be a problem with the file, but I can open
> it in MapInfo, as well as Global Mapper 13, so I think the file is OK.
> Is there a way to explicitly specify to gdal_translate the format of
> the input file? I don't see an option for this in the list of
> command line switches.
> I put the .grc/.tab file pair in a zip (~5.3 Mb) at
> http://dl.dropbox.com/u/53500018/GdalOpenFailedGrid.zip if it helps.
> This is in version 1.9.0 of GDAL, by the way.
> Regards,
> Mladen
This message was sent using Distributel Webmail.
Ce message a été envoyé à partir de la Messagerie Web Distributel.
