[gdal-dev] python filegdb problems
Netherton, Kevin J FLNR:EX
Kevin.Netherton at gov.bc.ca
Tue Mar 20 18:19:04 EDT 2012
Been playing around a bit more. Originally when I ran ogrinfo it did not list any of the layers in the filegdb. All the feature classes in the geodatabase came from SDE and have geometry columns named 'geometry'. When I copied a shapefile feature class into the file geodatabase and then ran ogrinfo all of a sudden that layer was listed. The feature class that is getting listed has a geometry column called 'shape'.
Is there a switch or a parameter that will allow ogrinfo to see the other feature classes in the file geodatabase? I suspect that its looking for a geometry column called 'shape' and isn't finding it.
I copied the geodatabase to the following location in case that helps.
ftp://ftp.geobc.gov.bc.ca/pub/outgoing/GeoBC_Regional/SIR/Kamloops/ogr/arc10gdb.zip
-----Original Message-----
From: Stefano Iacovella [mailto:stefano.iacovella at gmail.com]
Sent: Tuesday, March 20, 2012 2:04 PM
To: Netherton, Kevin J FLNR:EX
Cc: gdal-dev at lists.osgeo.org
Subject: Re: [gdal-dev] python filegdb problems
Did you run ogrinfo arc10geodb.gdb on a shell?
Does it show the layers inside the fileGDB or it throws some error?
Stefano
2012/3/20 Netherton, Kevin J FLNR:EX <Kevin.Netherton at gov.bc.ca>:
> Hello
> I'm trying to get the python bindings to the ogr library working with esri
> file geodatabase (filegdb) support. I am using the latest version of ms4w
> package that includes gdal/ogr 1.9.
> I have created a esri file geodatabase driver, then from that created a data
> source, but am unable to access layers from the data source object. Below
> is a quick summary of my code:
> drvrObj = osgeo.ogr.GetDriverByName(r'FileGDB') # print the driver
> retunrs a SWIG object
> path = str(r'C:\testdatadir\arc10geodb.gdb')
> mydataSrc = drvrObj.Open(path) # printing the data source prints a SWIG
> object
> lyrCnt = mydataSrc.GetLayerCount() # always returns 0 but there are many
> layers in the fgdb
> lyr = mydataSrc.GetLayer(0) # always returns null
> The comments in the code above kind of summarize the situation. It appears
> that I can create a valid datasource but am unable to read the layers inside
> the datasource. Any ideas?
> gdal-dev mailing list
