[gdal-dev] Contrast, Brightness and Gamma
Chaitanya kumar CH
chaitanya.ch at gmail.com
Thu Mar 22 14:42:49 EDT 2012
Saâd,
Can you provide the vrt file and the commands you used?
On Thu, Mar 22, 2012 at 11:22 PM, Saâd HESSANE <saad.hessane at gmail.com>wrote:
> Hy Chaitanya,
> I applied a LUT to the VRT. It's work fine, and all pixel are between
> dst_min and dst_max.
> But why this is not work with the -scale parameter? The doc is clear :
> http://www.gdal.org/gdal_translate.html.
> "Rescale the input pixels values from the range *src_min* to *src_max* to
> the range *dst_min* to *dst_max*."
> Is it a bug?
> 2012/3/22 Chaitanya kumar CH <chaitanya.ch at gmail.com>
>> Saâd,
>> It is better to have a combined LUT. It will save processing time and
>> data degradation.
>> Be informed that GDAL VRT is not specialized for this work. To get a
>> smooth curve as LUT, use some other graphics application that can handle
>> 16bit rasters.
>> On Wed, Mar 21, 2012 at 6:00 AM, Saâd HESSANE <saad.hessane at gmail.com>wrote:
>>> Thank's all for your answers.
>>> I will use the LUT method, cause is the most right for me.
>>> Chaitanya said : "Gamma correction is more related to displaying the
>>> data than the data itself".
>>> Not in my case. I have to do this correction. But how to do that? Do i
>>> embed a VRT with a contrast correction LUT, in another VRT with a gamma
>>> correction LUT ? Or there is a method to declare LUTs in order to execute
>>> in the same vrt ?
>>> Thank's again !
>>> 2012/3/20 Brent Fraser <bfraser at geoanalytic.com>
>>>> I like to use gdal_contrast_stretch from
>>>> http://www.gina.alaska.edu/projects/gina-tools/
>>>> Usage: gdal_contrast_stretch <src.tif> <dst.tif>
>>>> { { -linear-stretch <target_avg> <target_stddev> } |
>>>> { -percentile-range <from: 0.0-1.0> <to: 0.0-1.0> } |
>>>> { -histeq <target_stddev> } }
>>>> [ -ndv <no_data_val> ]
>>>> Input must be either 8-bit or 16-bit. Output is 8-bit.
>>>> For example:
>>>> gdal_contrast_stretch -percentile-range 0.02 0.98 input16bit.tif
>>>> output8bit.tif
>>>> Best Regards,
>>>> Brent Fraser
>>>> On 3/20/2012 9:55 AM, Saâd HESSANE wrote:
>>>> Hi list,
>>>> I use gdal_translate to convert 16bits images to 8bits images. The
>>>> gdal_translate have the -scale argument to specify the convertion range
>>>> (source->destination).
>>>> If I change the destination range (dst_min and dst_max), I can do
>>>> manually a brightness correction (also a contrast correction).
>>>> But is there any way to do that with a Photoshop like method?
>>>> For example set a brightness to -50, a contrast to +8 and let
>>>> gdal_translate do the job ?
>>>> Also can I apply a gamma correction?
>>>> I saw the VRT format and there's a way to apply a LUT. But I don't
>>>> think a LUT of 65536 values is the best way to apply the correction.
>>>> Also the VRT have the scale ratio and scale offset elements. I think it
>>>> can be useful but I don't understand how use it...
>>>> So simply put, my question : can I do a contrast, brightness or gamma
>>>> correction to a raster with gdal?
>>>> Thank you !
>>>> PS : I apologize for my broken English !
>>>> _______________________________________________
>>>> gdal-dev mailing listgdal-dev at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/gdal-dev
>> Best regards,
>> Chaitanya kumar CH.
>> +91-9494447584
>> 17.2416N 80.1426E
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120323/51da3089/attachment.html
