[gdal-dev] VRT derived band, pixel functions and Python bindings
Armin Burger
armin.burger at gmx.net
Thu Mar 22 16:52:03 EDT 2012
On 22/03/2012 21:00, Even Rouault wrote:
> Le jeudi 22 mars 2012 19:26:56, Armin Burger a écrit :
>> Hi all
>> I set up 2 pixel functions to be used with VRT images and derived bands.
>> This works fine with the GDAL utilities and also with MapServer and
>> Python MapScript.
>> If I try however to load the pixel functions in GDAL-Python as drivers,
>> I run into problems. The following code
>> from osgeo import gdal
>> import os
>> os.putenv("GDAL_DRIVER_PATH", "/usr/local/share/gdal/gdalplugins")
>> gdal.AllRegister()
>> produces the error:
>> python: symbol lookup error: /usr/local/share/gdal/gdalplugins
>> /gdal_SpotBlue.so: undefined symbol: GDALAddDerivedBandPixelFunc
>> So is this sort of a bug or is this functionality not available via the
>> GDAL Python bindings? Environment is Linux, GDAL 1.9, Python 2.6.
> No fundamental reason it should not work. I'm pretty sure to have done that in
> the past. Did you make sure that your gdal_SpotBlue.so links to libgdal.so
> (check with ldd) ? But I'm not sure why loading throug python would make a
> difference w.r.t loading with GDAL utilities or MapServer.
Even
compilation was with
gcc -fPIC -c SpotBlue.c
gcc -shared SpotBlue.o -o SpotBlue.so
So no spacial linking against libgdal.so. ldd therefore does not report
anything related to the libgdal.so. But since it directly worked from
the normal GDAL utilities and MapScript I did not check anything further.
What would be your suggestion for additional flags to add for the
compilation?
Armin
