[gdal-dev] Precision about scale/offset element in VRT file
Chaitanya kumar CH
chaitanya.ch at gmail.com
Fri Mar 23 13:29:39 EDT 2012
Output pixel value = (raw pixel value * scale) + offset
On Fri, Mar 23, 2012 at 5:44 PM, Saâd HESSANE <saad.hessane at gmail.com>wrote:
> Ok, thank you again Chaitanya,
> But what is the function of this two element?
> 2012/3/23 Chaitanya kumar CH <chaitanya.ch at gmail.com>
>> Saâd,
>> A VRT raster band can be derived from more than one source.
>> Offset and Scale elements apply to the whole VRT raster band.
>> The ScaleOffset and ScaleRatio perform the same task but it is done only
>> on that particular ComplexSource.
>> On Fri, Mar 23, 2012 at 3:43 PM, Saâd HESSANE <saad.hessane at gmail.com>wrote:
>>> Hy all,
>>> The vrt format allow defining the scale and offset element. But the
>>> documentation is not clear about that :
>>> - *Offset*: This optional element contains the offset that should be
>>> applied when computing "real" pixel values from scaled pixel values on a
>>> raster band. The default is 0.0.
>>> - *Scale*: This optional element contains the scale that should be
>>> raster band. The default is 1.0.
>>> What that it's mean ? If the value of offset is 1 what that it's change?
>>> And this two elements are use in the *VRTRasterBand* element. What
>>> about *ScaleOffset* and *ScaleRatio* in the *ComplexSource* element?
>>> Thank you.
>>> gdal-dev mailing list
>>> gdal-dev at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
>> Best regards,
>> Chaitanya kumar CH.
>> +91-9494447584
>> 17.2416N 80.1426E
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120323/71085aaf/attachment.html
