[gdal-dev] ogr2ogr, gpx -> PostGIS, preserving fid links
James Hiebert
hiebert at uvic.ca
Mon Mar 26 10:55:55 EDT 2012
> The ticket #3637 was invalid because there was nothing to fix. The change in
> track_fid values was not unexpected.
Good to know. I guess as a very periphrial GDAL user, I'm still learning what to expect and what is not core functionality.
> Please let us know how you solved this issue.
It turned out that a pretty simple python script solved my problem (thanks largely to the "Retrieving FID of newly inserted feature" from here: http://www.gdal.org/ogr/drv_pg_advanced.html). Without any attempt to optimize for performance or catch any errors, it can be expressed in a short page (below) and seems to do the right foreign key mapping; at least for the several test cases that I tried. We'll see what happens when I go to load years worth of data :)
Thanks for the feedback.
~James
import ogr
rd = ogr.Open('/path/to/my/file.gpx')
wt = ogr.Open("PG:dbname='spatial' host='my.host' user='me' password='******'")
rlyr = rd.GetLayerByName('tracks')
wlyr = wt.GetLayerByName('tracks')
fid_map = {}
# Copy tracks, saving the database fid
for feat in rlyr:
fFID = feat.GetFID()
feat.SetFID(-1)
rv = wlyr.CreateFeature(feat)
fid_map[fFID] = feat.GetFID()
print "fid map:", fid_map
ptrlyr = rd.GetLayerByName('track_points')
ptwlyr = wt.GetLayerByName('track_points')
# Copy track-points using the database track_fid rather than the file track_fid
for feat in ptrlyr:
feat.SetFID(-1)
feat.SetField('track_fid', fid_map[feat.track_fid])
rv = ptwlyr.CreateFeature(feat)
On Mon, Mar 26, 2012 at 01:33:51PM +0530, Chaitanya kumar CH wrote:
> James,
> Whatever we do, we need to keep track of the foreign keys. That is not a
> trivial case. It is more of a DBMS area. In fact, the solution you specified,
> which is to have a temporary table, was my first idea too.
> On Mon, Mar 26, 2012 at 10:29 AM, James Hiebert <hiebert at uvic.ca> wrote:
> Hi all,
> I'm trying to use ogr2ogr to load gpx tracks into PostGIS and am having
> trouble preserving the foreign keys between the "track_points" layer/table
> and the "tracks" layer/table.
> My use case is as such:
> I typically collect gps traces in the field and use gpsbabel to download
> the traces from one of my gps receivers. Afterwards I want to load them
> into PostGIS, adding the trace(s) from the last period of time to my
> archive of gps traces from the past several years. When inserting into
> PostGIS, I would like to include both the track_points layer (to include
> all of the point attributes such as time, elevation, hdop/vdop, etc.) and
> the tracks layer. I would like for each of the track_point rows to include
> a foreign key to the corresponding track and GDAL's GPX driver seems to
> support this according to here: http://gis-lab.info/docs/gdal/
> gdal_ogr_user_docs.html
> Whenever running ogr2ogr in append mode, however, the track_fid column of
> the track_points are never translated to account for what is the actual fid
> of the corresponding track. For example, if there are already 10 tracks in
> my database, and the track fid sequence is at 10, the new track will be
> loaded in with fid=10, but the track_points from that track will be loaded
> in with track_fid=0 (i.e. it points to the track_fid in the new gpx file,
> not the database).
> I thought that perhaps the -preserve_fid command line switch would help,
> but it's essentially useless in -append mode. If you're adding a new set
> of tracks to the database, there's no point in preserving the fids; all of
> the fids (0-n) in the new gpx file have all been used up by the existing
> tracks in the database and I'll just get primary key errors on anything
> after the first insertion. I think that I'm missing something. For
> example, I don't really understand why this old ticket http://
> trac.osgeo.org/gdal/ticket/3637 is marked as invalid. Perhaps it's just
> that my use case isn't supported by ogr2ogr? (If so, let me know and I'll
> move on).
> What's my best solution here? Is there an easy way out that I'm not
> thinking of/don't know about, or do I have to do some several step process
> like use ogr2ogr to insert into a temprorary table and then move them into
> the multi-track archive using a select/insert? Or should I just not use
> ogr2ogr and write my own program with GDAL which retrieves the track_fid
> upon writing that layer and then uses it for writing the track_points
> layer?
> FWIW I'm using GDAL 1.9.0, PostgreSQL 9.1.3 and PostGIS 1.5.3-r1 all built
> on Linux.
> Cheers,
> ~James
> gdal-dev mailing list
> gdal-dev at lists.osgeo.org
> Best regards,
> Chaitanya kumar CH.
> +91-9494447584
> 17.2416N 80.1426E
