[gdal-dev] GDAL Tiling
    Chaitanya kumar CH
    chaitanya.ch at gmail.com
    Tue Mar 27 14:42:11 EDT 2012
Akhy,
Block size is determined/set at the time of file creation. The only way to
change it is to make a different file with the desired block size. Not all
raster formats support setting custom block sizes. GeoTIFF does.
On Tue, Mar 27, 2012 at 11:05 PM, akshay gupta <akshaygupta202 at gmail.com>wrote:
> Thanks for your quick reply,
> I dont want to use GDALRasterIO, I dont want to allocate memory of size
> equal that of image or ROI, i want to make use of tiling as much as
> possible. Can you provide more detail on how to create tiles tiff files by
> default.
> Akhy
> On Tue, Mar 27, 2012 at 9:30 PM, Chaitanya kumar CH <
> chaitanya.ch at gmail.com> wrote:
>> CKYSIZE [1].
>> 2) You can read the raster any way you want using the GDALR
Best regards,
Chaitanya kumar CH.
+91-9494447584
17.2416N 80.1426E
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120328/97b7e3e8/attachment.html
