[gdal-dev] MDB tools - SOLVED
Zoltan Szecsei
zoltans at geograph.co.za
Wed Mar 28 10:08:52 EDT 2012
Sorry - I didn't try he simple idea first:
Just use mdb-schema from mdb-tools.
Apologies for the bandwidth wastage.
Regards,
Zoltan
On 2012/03/28 15:57, Zoltan Szecsei wrote:
> Hi All,
> I am trying to find a way to list the data type of each field in all
> tables in a GeoMedia MDB databse.
> I tried ogrinfo mdbname and got: ERROR 1: PGeo: MDB Tools driver not
> found!
> so, sudo apt-get install mdbtools, and tried again and got same error.
> so, sudo apt-get install gdal-bin and that gave me a newer version
> than that I did have.
> Interestingly apt-get returned: Setting up gdal-bin
> (1.9.0-1~exp5~lucid4) ...... etc etc
> but afterwards: ogrinfo --version still returns GDAL 1.8.1, released
> 2011/07/09
> Anyway, still no avail:
>> zls at gs0:~/q4x$ ogrinfo SSC_WC_Q43.mdb
>> ERROR 1: PGeo: MDB Tools driver not found!
>> Warning 1: Unable to install MDB driver for ODBC, MDB access may not
>> supported.
>> ERROR 1: Unable to initialize ODBC connection to DSN for
>> DRIVER=Microsoft Access Driver (*.mdb);DBQ=SSC_WC_Q43.mdb,
>> [unixODBC][Driver Manager]Data source name not found, and no default
>> driver specified
>> supported.
>> driver specified
>> FAILURE:
>> Unable to open datasource `SSC_WC_Q43.mdb' with the following drivers.
>> -> ESRI Shapefile
>> -> MapInfo File
>> -> UK .NTF [etc tec]
> I then removed the packages and reinstalled them using synaptic, only
> to get errors regarding no gdalinfo in /usr/local/bin, even though
> which gdalinfo returns /usr/bin/gdalinfo (without the 'local')
> Can anyone spot my deliberate mistake?
> Will ogrinfo be able to give me the schema printout that I want, or is
> there a better way?
> (I am not an Access user)
> Thanks in advance,
> Zoltan
Zoltan Szecsei PrGISc [PGP0031]
Geograph (Pty) Ltd.
P.O. Box 7, Muizenberg 7950, South Africa.
65 Main Road, Muizenberg 7945
Western Cape, South Africa.
34° 6'16.35"S 18°28'5.62"E
Tel: +27-21-7884897 Mobile: +27-83-6004028
Fax: +27-86-6115323 www.geograph.co.za
