[gdal-dev] Minor problem with the OGR clipping
Eric Grosso
eric.grosso.os at gmail.com
Wed Mar 28 22:59:39 EDT 2012
Frank,
Done.
URL: http://trac.osgeo.org/gdal/ticket/4590
Cheers,
Eric
On 29 March 2012 04:41, Frank Warmerdam <warmerdam at pobox.com> wrote:
> Eric,
> If you could file a ticket on the issue we can make the "looks like a
> geometry"
> logic more bulletproof.
> Best regards,
> Frank
> On Wed, Mar 28, 2012 at 7:27 PM, Eric Grosso <eric.grosso.os at gmail.com>
> wrote:
> > Hi,
> > I was writing a small OGR based script (bash) in order to clip several
> > shapefiles at the same time.
> > Thus I used this piece of code: ogr2ogr -clipsrc polygon_selection.shp
> > output.shp input.shp
> > Using it, I had the following error: "FAILURE: Invalid geometry. Must be
> a
> > valid POLYGON or MULTIPOLYGON WKT"
> > I checked my polygon_selection.shp file. It was "OGC" valid. Then I
> checked
> > the documentation. Apparently it was correct.
> > So I finally decided to check the code and I understood why I had this
> > message.
> > If the filename of the polygon which is used to do the clipping begins
> with
> > "polygon" or "multipolygon", the code tries to convert
> > this argument in WKT.
> > Here is an code extract of ogr2ogr.cpp (same for -clipsrc and -clipdst
> > options):
> > else if (EQUALN(papszArgv[iArg+1], "POLYGON", 7) ||
> > EQUALN(papszArgv[iArg+1], "MULTIPOLYGON", 12))
> > I let you decide what to do (add this very minor problem to the
> > documentation or change a bit the code,
> > e.g. "POLYGON", 7 becomes "POLYGON(", 8 could do the trick). That's why I
> > didn't open any bug report or enhancement request.
> > First time I write on this list, so I catch the opportunity to thank all
> the
> > developers of GDAL/OGR for your wonderful work.
> > Cheers,
> > Eric
> > gdal-dev mailing list
> > gdal-dev at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/gdal-dev
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Software Developer
URL: http://lists.osgeo.org/pipermail/gdal-dev/attachments/20120329/b8f0973f/attachment.html
