[gdal-dev] Interpretation of DTED elevation data
    Alex Barféty
    alex.barfety at signalis.com
    Thu Mar 29 12:02:06 EDT 2012
I've used the ReadRaster method with a short array and it working perfectly
fine, the elevation data recovered are correct.
Thanks for your advice :)
Alex Barféty
-----Message d'origine-----
De : Even Rouault [mailto:even.rouault at mines-paris.org]
Envoyé : mercredi 28 mars 2012 10:23
À : AlexRNL
Cc : gdal-dev at lists.osgeo.org
Objet : Re: [gdal-dev] Interpretation of DTED elevation data
Selon AlexRNL <alex.barfety at signalis.com>:
> Hi everyone!
> I have been trying to extract elevation data from a DTED file using
> GDAL (in Java). The file being loaded is of level 0 precision and
> seems to be correct as an import into Global Mapper is rendering the
expected result.
> I managed to retrieve the image data but I don't know to transform
> those values into a altitude in meters.
> According to the DTED format specification, the elevation values are
> supposed to be two-bytes integer in meters. But, when using the
> http://www.gdal.org/java/org/gdal/gdal/Band.html#ReadRaster_Direct(int
> , int, int, int, int, int, int, java.nio.ByteBuffer) ReadRaster_Direct
> method, the buffer retrieved is supposed to be composed of Int16
> number but when i'm converting the raw data (bytes) into a short array
> i'm getting all sorts of value which doesn't make a lot of sense. The
> range of the elevation is spanning from 1 to 65286!
> Is there a conversion that i'm missing? How do I get the meter value
> from the raster returned by GDAL?
You should make sure to request with buf_type = gdalconst.GDT_Int16. Then
iterating the buffer with getShort() should deliver the expected values.
Otherwise use the version of ReadRaster() that accepts a short[]. That will
be simpler to use.
The benefit of using ByteBuffer instead standard Java arrays only appears
with
*huge* arrays
> I've been searching for a while but it doesn't seem like anyone has
> that kind of problem...
> Thanks in advance for any information that may help me :)
> Alex.
http://osgeo-org.1560.n6.nabble.com/gdal-dev-Interpretation-of-DTED-elevatio
n-data-tp4663511p4663511.html
> Sent from the GDAL - Dev mailing list archive at Nabble.com.
