[gdal-dev] Re: Error in creating gml file
Salvatore Larosa lrssvtml at gmail.com
Thu Mar 29 17:54:45 EDT 2012
Il giorno gio, 29/03/2012 alle 14.47 -0700, proto83 ha scritto:
> ok i did it and i the output was this.
> INFO:Open of 'c:\shapefiles\oikismoi_irakliou.shp'
> using driver 'ESRI Shapefile' successful
> 1:oikismoi_irakliou <Point>
Can you try ogr2ogr command in a different folder?
For example in the Desktop folder.
