[gdal-dev] Re: Error in creating gml file
proto83 proto83 at hol.gr
Fri Mar 30 10:32:27 EDT 2012
ok i understood and i solved the problem.i did this on another hard disk that
i have without any problem.
So,everything is ok.thank you for your help.
View this message in context: http://osgeo-org.1560.n6.nabble.com/Error-in-creating-gml-file-tp4669016p4671470.html
Sent from the GDAL - Dev mailing list archive at Nabble.com.
