[gdal-dev] RFC 39
Ari Jolma ari.jolma at gmail.com
Thu May 3 05:12:15 EDT 2012
On 05/03/2012 11:27 AM, Peter Halls wrote:
> Ari,
>     as a user (and teacher of users), I would urge you to keep to the
> model where the output is always a new object (actually the same as
> ArcGIS), rather than consider modifying an input for any of these
> spatial operations.  That automatically solves the read-only input issue.
Peter,
At least Perl, probably some other languages too, detect between the two
usages:
C = A.method(B)
and
A.method(B)
and adjust accordingly. Compare for example to
C = A + B
and
A += B
which is commonly supported in programming languages. In principle, I
would support (as I wrote) implementing only the in-place version, and
allow the new object syntax and implement it using the in-place for a
new object. But, as I wrote, GDAL is often geared towards the former
paradigm and datasets are often read-only. So, in this case we'll go the
other way. I want to support the latter paradigm (in-place) in Perl
bindings - it is often more useful in interactive work, where one may
typically manipulate a dataset in several steps.
Best regards,
Ari
