Re: [gdal-dev] Get SRID from image file
Ivan Lucena ivan.lucena at princeton-ma.us
Thu May 3 11:56:50 EDT 2012
Billy,
The GeoRaster driver will do that for you. It takes the EPSG Authority code from the input file and use it as SRID when loading the image to the database sdo_georaster object. For more info: http://gdal.org/frmt_georaster.html
Regards,
Ivan
>  -------Original Message-------
>  From: Billy Newman <newmanw10 at gmail.com>
>  To: gdal-dev at lists.osgeo.org
>  Subject: [gdal-dev] Get SRID from image file
>  Sent: May 03 '12 10:38
>  I have some image files (geotiff's) and I would like to store some of
>  the metadata about the image files in oracle spatial.  Is there any way to
>  get the SRID for an image file?
>  Thanks,
>  Billy
>  _______________________________________________
>  gdal-dev mailing list
>  [LINK: compose.php?to=gdal-dev at lists.osgeo.org] gdal-dev at lists.osgeo.org
>  [LINK: http://lists.osgeo.org/mailman/listinfo/gdal-dev]
